I recently went to Advance Auto and the following codes popped up for my 94 850 Turbo.
P 0402 EGR Flow Excessive
P 1417 Manf Ctrl Aux Emission Ctrls
P 0326 Knock Sensor 1 Ckt Range/Perf, Bank 1 or Sensor 1
P 1505 Manf Veh Spd, Idle Spd Ctrl, Aux Inputs
P 1507 Manf Veh Spd, Idle Spd Ctrl, Aux Inputs
I replaced the EGR and would like to know where the main problem lies & how can I fix it. I'm not aan experienced person but it seems to be either an MAF Sensor problem because the car will not idle smoothly without high revs (2,000 - 3,000 RPM).
Any help would be appreciated.
Thanks so much & I love this car !!!!
94 850T Codes
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
You were able to read your '94 850 diagnostic codes at AutoZone? It has an OBD port? I would again read your codes from the black diagnostic boxes under your hood and see what the Volvo specific codes are. I'm a bit surprised as I've never seen a '94 with an OBD port.
This shows you where the diagnostic boxes are:
http://www.volvospeed.com/850slight.php
This shows you the diagnostic codes for Transmission/Engine, etc:
http://www.volvospeed.com/maintence.htm#Lights
(DTC Codes...right under the upper heading)
I have a 94 850 as well, the OBD port is in front of the gear shift, to me it looks like a coin holder but you can pop it off and below it is the port where the reader plugs into it.MadeInJapan wrote:You were able to read your '94 850 diagnostic codes at AutoZone? It has an OBD port? I would again read your codes from the black diagnostic boxes under your hood and see what the Volvo specific codes are. I'm a bit surprised as I've never seen a '94 with an OBD port.
1994 850 Turbo Wagon - 218,000 Miles
Luther White
- Year and Model:
I too have a 94 854T and it also has an OBD II port although I have never used it, just use the diag...box under the hood.
Luther White
1994 Volvo 850 Turbo
170,000 miles
170,000 miles
MadeInJapan
Interesting...had heard of a few '95's with OBD-II ports, but not '94's.
mta58
- Year and Model: 1997 850 GLT
Dear Everyone:
This is not the official OBDII/Code reader post.
As an update, I replaced the Idle Speed Motor and finally the MAF Sensor. When the MAF was replaced, the CEL light went out and now only the service light is on. I am taking the car to an auto mechanic in Atlanta close to our house to find out why it still won't idle normally. My best guess is that a vacuum hose is misconnected when I replaced the EGR. You must remove a lot of hoses and other devices to do this and I must have done something wrong although everything seems to be in it's proper place.
Will keep eevryone updated.
- 952 Views
Last post by Ozark Lee
- 1190 Views
Last post by 850TurboTurtle
- 1057 Views
Last post by Klausc
- 19 Replies
- 10374 Views
Last post by Barledge
- 1906 Views
