Time for new o2?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
98's all used Bosch (all ME 4.4 systems). 99+ non-turbos had a Denso system.
'98 S70 T5
2016 Chevy Cruze Premier
echase76
- Year and Model: 1998 v70 T5m
Will be getting a Bosch 15097. The car is Stage 0 plus a new radiator so I'm willing to throw down the extra cash for the right part. I'm not looking to have to do this again anytime soon!
1998 V70 T5m Silver/Charcoal - 150K
macs70GLT
- Year and Model: S70 GLT 1998
I replaced my front O2 sensor over the weekend, PB Blaster works great to loosen it up. For me the hardest part was getting to & disconnecting the electrical plug. You have to unclip it from the metal bracket, slide out a brown tab from the side, then the connector will come out. Probably would have helped if I had the car raised higher (I got it from underneath). You could also remove the large air hose that goes down to the turbo. With all that stuff in the way - very difficult access ....
I did use the Bosch 15097 - cleared the P0133 code.
Lars: 1988 245, 250K mi retired
Son of Lars: 1998 S70 GLT, 225K mi retired
Beast Mode: 1995 940T, 213K mi
Son's car: 1998 V70 GLT, 182K mi
Hans: 2002 Audi A4 QMT, 142K mi
echase76
Thanks for the replacement report. My part arrives tomorrow and will be tackling the job this weekend. I have heard getting to the plug is a bear, especially on a turbo. I'll have it up on ramps and may move the air pipe out of the way as I'm planning to replace the harness also.
Glad to hear it cleared your P0133!
I'll let folks know how it goes.
jblackburn
If you can work it loose from the bracket from behind the transmission at the bottom, pulling the entire wiring harness up into reach from the top makes the plug MUCH easier to separate.
'98 S70 T5
echase76
Replaced the O2 sensor today. Turns out someone had put in an aftermarket cheap-o. No wonder I was getting codes.
Put that car up on ramps and accessed it all from underneath. Things were just too cramped from above and I didn't want to take off the intake pipe. Turns out that access is pretty good from below due to multiple angles to work from. If you explore all the places you can get your hands around the transmission it is a fairly easy job (this is on a manual).
What took me the longest was unplugging the wrong one first! I thought I was unplugging the black plug for the front, but when I pulled it out it was the gray rear O2.
Thanks to everyone for helping get this sorted out.
tjts1
- Year and Model: 96 855 NA 5 speed
- Been thanked: 4 times
Well I guess you'll have to add me to the crim connector camp. I built entire EFI harnesses with crimp connectors without a problem.erikv11 wrote:Just for the record, on the forum sites there is wide disagreement about putting a crimp-to-fit oxygen sensor into a Volvo. Some people say the crimp method works fine, some say it might work at first but in any case will never last more than a year before throwing a CEL. YMMV.tjts1 wrote:Replace it, its dirt cheap. I used a Bosch 13877 sensor. $15 on Amazon. Just have to crimp the 4 wires. Works great.
Ambitious but rubbish
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Is there a way to read the health of your O2 sensor with the live data feature on a OBD-II code reader?
- 25 Replies
- 7161 Views
Last post by Blacklab467
- 2170 Views
Last post by foggydogg
- 1397 Views
Last post by Legofan
- 10 Replies
- 1863 Views
Last post by MrAl
- 750 Views
Last post by cn90
