94 Volvo 850 GLT
Forum rules
volvo850black
Year and Model: volvo 850 1994
Post by volvo850black »
11- April-2010 Replaced timing belt
11-April-2010 Replaced guage cluster with new OEM
11-Nov-2010 Replaced drivers side half axle with used OEM
05-April-2011 Replaced front Struts with Monroe and Spring seats with OEM
05-April-2011 Replace ball joints and control arms with new OEM
05-May-2011 Replaced spark plugs with champion platniums
01-Jun-2011 Replaced Fuel pump relay with used OEM
18-Feb-2012 Replaced Ignition ECM with remanufactured used from 96 GLT
18-Feb-2012 Replaced Cam Shaft Sensor with new OEM
18-Feb-2012 Replaced Crankshaft Sensor with new OEM
18-Feb-2012 Replace igniter with new OEM
MattC 94 854 NA and 96 855 turbo
