Hi Guys,
I am looking at buying a 1999-2003 C70 T5 Coupe.
My question is, all the pictures that I find of the cars for sale have a different gearshift console to my 1998 V70 T5 in that they only have the "w" button and not the "E" and "S" buttons.
I am aware that some of these (if not all) had the 5 speed auto box SN55-50.
Are these problematic like the ones in the 2000-2002 P2 Cars?
Thanks in advance
1999-2003 C70 coupe?
- Year and Model: Lots
- Been thanked: 128 times
driesbabe wrote: I am aware that some of these (if not all) had the 5 speed auto box SN55-50.
Thanks in advance
Yep, especially the earlier ones. I have a 2000 V70 with this trans that we are nursing at the moment (though the new B4 servo cover made it much better)
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
The 2001 C70 models saw the 5 speed.
We all know 2001 Volvos are bad, bad things. Stay with a 1999-2000 with the 4 speed and you'll make a wise choice.
'98 S70 T5
2016 Chevy Cruze Premier
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
through 98 Volvo used the selectable S/E with Winter mode switch. 99 and later have the two shift schedules decided on by the TCM based on your throttle application. Less aggressive throttle use gets you the softer sooner upshifts of the previous E setting and aggressive throttle gets you the S mode.
Xilikon
- Year and Model: 2000 V70 XC SE
Got the same answer when I aked before. With the TCM, there is no need for the separate selectors beside the W (this one put the car in 3rd gear from the start to avoid spinning the wheels). The TCM was new in 1999 along with the new ME7.jimmy57 wrote:through 98 Volvo used the selectable S/E with Winter mode switch. 99 and later have the two shift schedules decided on by the TCM based on your throttle application. Less aggressive throttle use gets you the softer sooner upshifts of the previous E setting and aggressive throttle gets you the S mode.
2000 V70 XC SE with 150,000 miles, still going great !
- 695 Views
- 438 Views
Last post by Rainie
- 933 Views
- 1970 Views
Last post by RickHaleParker
- 653 Views
Last post by dosbricks
