Thanks jblackburn,
Good to know there is a shim kit for the rear!
JML99,
The feathering is due to toe wear as camber wear is just a wedge type wear and in the case of neg toe with neg camber it is on the inside. Try to find a good alignment shop to see if they can shim that toe out. It is not that out of spec if I can remember specs well enough or else it is to a body shop for some stretching and bending.
Blessing,
rear end alignment
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
- 9 Replies
- 770 Views
Last post by Sveedy
- 12 Replies
- 2618 Views
Last post by erikv11
- 15 Replies
- 4451 Views
Last post by wizechatmgr
- 17 Replies
- 3230 Views
Last post by skloon
- 1903 Views
