96 850 driver window won't go down
So needless to say that I found out in the drive thru of Wendy's that my driver window doesn't go down. All other windows work just fine and I can hear it click when I press the down button, but nothing happens. Help! Where do I start looking?
G. M. Hall
1996 Volvo 850 2.4 (Non-Turbo)
VT Alum (2007) GO HOKIES!!!
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Could be the switch or motor. Does it move at all?
Ben850
- Been thanked: 7 times
Due to the location of the window switches they are a prime target for beverage spills. Might you have had an accidental drink spill? Some electrical contact spray may be an easy fix. The swithches can go bad, but I found mine worked fine after some cleaning.
Also, my passengers window did'nt work, so when I pulled the door panel, I found the motor was simply unplugged where a zip tie had come loose. All is now well.
Good luck.
Good luck.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Ben850
No need to remove it. You can try electrical contact cleaner, spraying into the switch while clicking it back and forth.(power off) Use the spray generously, but allow about a half hour to dry if you dowse it heavily.
- rspi
Contact rspi..
I've taken the switches apart on my 960. Had some carbon build-up in there on the contacts. It would move one way or the other but did finally stopped working untill I pulled it apart, cleaned it up with some fine sand paper and put it back together.
