snabb users tell me what you thought.
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
gentlejax
Year and Model: 1998
Post by gentlejax »
I finally got around to ordering one of the snabb intake kits for my s70 t5. Been wanting to get this for a while and since I ordered a new pcv system it was a good time to get it and do it all at same time.
have not got it yet
in the meantime, what do other users think?
RobTarD
Year and Model: V70R, 1999
Post by RobTarD »
I honestly couldn't tell much of a difference, but I don't spend much time in the upper RPMs. It's a nice piece, though.
t5ftw
Year and Model: 1999
Post by t5ftw »
Mine is 99 s70 T5, and the fitments were not great. Performance-wise, I noticed slight gain at upper RPM but I think it got weaker at lower RPM. Maybe you need to do further intake mod to take full advantage of it. If you are not going to do so and you have a perfectly working intake pipe, i would think again whether there is other urgent repair to pay. Exhaust sound got a little louder. I have EST cat back, and it was not always loud, but now it is always loud. Hose themselves and the clamps seem to be quality parts. Because of that fittments issue, hoses had to be put on with some angle instead of going on straight. So, I had to tighten the clamps real hard to reduce leak. I don't think this will help the hose last long. Another problem was that the PTC grommet were loose. There was a visible gap between the grommet and the pipe, allowing some of un-metered air leaking through it. Somehow, my car is very sensitive to this kind of leak. So, I put some gasket sealant around it. Still, I don't think it is perfectly sealed. It may be working better for 98 cars because I read lots of positive reviews from the owners of 98.
gentlejax
Post by gentlejax »
well I havnt put it on yet. thats not the best sign to hear out of the 2 replies.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
I have one, and I like it! I also installed with with a K&N Ea cone filter though, so I can't really attribute the cool new sound and minor performance increase to one alone. I didn't really have any major problems installing the snabb, but it was a little tricky to get all the parts lined up right before cranking them down. Sometimes if they weren't on all the way, the tightening of the bolts made a silicon piece slip off. This was remedied by making sure they were fully seated first.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
gentlejax
Post by gentlejax »
Anyone else ? I have a 99 t5 by the way. not sure if I want to install this now.
bronxnativ
Year and Model: 96 850 GLT 5 Speed
Post by bronxnativ »
On a side note; I'm glad Snabb was brought up. I recently purchased what he described as a "refurbished" throttle plate. I was seriously disappointed when I received it! It was USED, not REFURBISHED as he describes! It has deep gouges on one side, as if someone had a difficult time removing the two screws. No attempt to clean it up or hide it. Because of this I will never purchase from him again. Yes, this little $25 part is a direct reflection of his products and service.
Al
RobTarD
Post by RobTarD »
Did you take this up with Snabb? So far everyone has been pleased with their products and service.
Beck
Year and Model: 04 V70 2.5T AWD
Post by Beck »
It's a good compliment to an already upgraded turbo back exhaust system. Without that or a tune you won't feel a thing. I noticed quicker spool up and throttle response on the highway.
almostarctic
Year and Model: v70xc 1999 C30 2008
Post by almostarctic »
I have the Snabb pipe in my mostly stock lpt v70xc 1999 (Mo 7). I found early take off was improved and engine noise was louder. Fitment was an issue so I used a heat gun to soften the silicone as i was making adjustments No problems with the ptc nipple. Looks great sounds great. Minor performance gains. Probably better with a ARD tune which can be set to take advantage of the improved airflow.
