I have looked through MVS posts on oil change, and procedures. It is clear, and I have everything (ramp and accessories, filters, tools, weather, and a radio station) to proceed with it this weekend, except the motor oil.
I do not know what types are in these engines already. I am hoping to pick up a case or two on sale, natural or synthetic. Is it prudent to switch both cars to one type such as 0W30 Synthetic for both P80, and P2 engines?
TIA!
which engine oil for both 1997-850 NA and 2001-V70XC
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I wouldn't use a 0W. You could go with a 5W-30 up in that area and probably be fine year-round.
If they're running on conventional oil (they probably are if you take it somewhere to have the oil changed), really no reason to change unless you drive them really hard or want to extend the change interval past 5000 miles.
Whichever you decide to go with, there are several good oils of both types.
'98 S70 T5
2016 Chevy Cruze Premier
xHeart
Pennzoil 5w30 (12/1qt) is about $37. Is this a good enough product?
Or Mobile 1 5w30 (6/1qt) for $32 (twice as much).
jblackburn
'98 S70 T5
xHeart
So, I will use Pennzoil 5w-30 conventional(?) motor oil for both cars. It is also money-wise for us. Thank you J!
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Purchased a new rebuilt motor for my 95 Grand Voyager 3.0 Mitsubishi Motor and put 50,000 miles and it still had hash marks in it when it lost a head-gasket. When I bought the van it also had a head-gasket problem on the original motor. They Mitsubishi and the re-builders could never quite get it right. The mechanic who replaced the head-gasket was second generation and he had never seen it before but these builders in the link have. Read page 2 about Dyno Testing and a High Performance shop comments.
There was a oil war waging in that forum
http://www.clubtitan.org/forums/showthr ... 584&page=2
- Been thanked: 818 times
Oil war? Compared to http://www.bobistheoilguy.com/forums/ub ... p?ubb=cfrm, that's not even a skirmish!
- instarx
- Year and Model: XC70 T6 2011
Using Mobil Oil's oil selection guide on their site, Mobil generally recommends different oils for your two cars, Mobil 1 5W-30 for the v70 and 10W-30 for the 850. However, it does also recommend 0W-30 Extended Life for both cars if you want to move to one motor oil for both.
There is also an interesting technical Q&A about 0W oils. Take a look.
http://www.mobiloil.com/USA-English/Mot ... .aspx?pg=1
Personally I like 0W oil for the extra start-up protection and I use 0W-30 in my V70 with fine results.
As for the conventional oil costing half as much... that isn't much of a saving if you have to change it at least twice as often.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
0W-xx oils are typically very well made. use them with confidence. Mobil 1 0W-30 is an outstanding oil, as is Castrol 0W-30 (Made in Germany). I wish people would stop spreading weird information about them.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
jblackburn
0W's are always a synthetic oil - there's really no need for the OP to go with one.
I noticed a huge difference in start-up smoothness (typically around 20-30 deg F - it runs easier for the first few seconds) switching to a 5W from a 10W on my car. That would improve the further you go north.
'98 S70 T5
- 9 Replies
- 9867 Views
Last post by RickHaleParker
- 11 Replies
- 4569 Views
Last post by gaasbox
- 9 Replies
- 17804 Views
Last post by combatkarl
- 9 Replies
- 6056 Views
Last post by CoOlCat
- 31 Replies
- 8209 Views
