My mechanic tells me that my check engine light is on due to a PCV Valve/vacuum leak. I'm currently driving a 1997 Volvo 850. he wants 300 bucks to fix the problem, but I think i can get it done elsewhere for a good deal cheaper. Is replacing the PCV valve itself all you need to do in order to rectify that sort of problem? Or do you need to replace the hose that connects to the PCV valve as well?
Thanks in advance!
PCV Valve vacuum leak?
- RobTheModd
- Year and Model: 98 S70T5M
- Has thanked: 5 times
- Been thanked: 7 times
Do you know the code it is throwing?
If not get it checked at autozone, or somewhere similar for free.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
The bad side of the PCV is that it gets clogged if not serviced properly and can cause massive oil leaks.
On the easy side of the system is that you get codes when you have vacuum leaks. You can usually find the leaks yourself. Check all the vacuum hoses and intake tube for leaks. If you have a car that is NOT turbo, check the flame trap (replace it). When I had the code, my small vacuum line at the back of the intake tube was loose. The car I looked at today had a massive leak at the intake tube just behind the MAF, it was 1/2 off the intake.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
P0172 is ALWAYS this hose - just behind the power steering pump. Here's how I fixed it when the stupid little elbow broke off on mine.
That space is tight and designed for people with hands the size of a 4 year old.
That said, the PCV system is probably clogged. Pull out the oil dipstick at idle and look for smoke puffing out of the tube. That indicates a clogged PCV system.
There is no simple PCV "valve". Instead, it's a needlessly complex system that's a royal pain in the butt to replace:
https://www.matthewsvolvosite.com/forums ... =1&t=28487
'98 S70 T5
2016 Chevy Cruze Premier
I've been messing around trying to get my new vacuum elbow installed and I just can't get in there and do it, in your picture am I missing something or is that an additional piece of hose? the replacement part I got was this.jblackburn wrote:P0172 is ALWAYS this hose - just behind the power steering pump. Here's how I fixed it when the stupid little elbow broke off on mine.
- main.JPG (7.63 KiB) Viewed 9637 times
jblackburn
It can be a real pain in the ass to reach. I had to remove the upper radiator hose - which just made everything slippery - in order to even get my hands in there. The next time it fell off, I bribed my girlfriend with cheesecake if she'd help me reconnect it with her tiny hands.
I added on a small piece of vacuum hose to mine as an extension, as the other hose fell down and couldn't be pulled up again to where I wanted it within the space confines I was trying to work in.
'98 S70 T5
Thanks for reply and I did same thing with coolant hose and it was very slippery. What end did you add the small piece of vacuum hose? from the intake? or other endjblackburn wrote:It can be a real pain in the ass to reach. I had to remove the upper radiator hose - which just made everything slippery - in order to even get my hands in there. The next time it fell off, I bribed my girlfriend with cheesecake if she'd help me reconnect it with her tiny hands.
jblackburn
It's attached to the end of the existing hose coming from the PTC valve at the back by the turbo.
If that hose is no longer there, then get some vacuum hose and run it from that intake port straight over the top of the engine, back to the turbo area.
'98 S70 T5
My bad, I didn't realize this thread concerned a turbo, mine is non turbo, does that make a difference? Here's a picture similar to what I'm working with (Note the arrow)jblackburn wrote:It's attached to the end of the existing hose coming from the PTC valve at the back by the turbo.
- 2536.jpg (47.45 KiB) Viewed 9617 times
