Central Locking Relay Location?
Madhelpermonkey
- Year and Model: 850-1996
Wow I never knew the alarm module was related here. The key does the same thing as the remote all locks unlock on first turn rather than divers first then the rest as it used to be. Would replacement of the alarm relay be in order? If yes then are there more than one type of alarm relay as there are locking modules?
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
The two-step unlock or one-step unlock is a feature (option) that can be programmed when re-learning the remote fob.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
Madhelpermonkey
Cant you direct me to instructions on doing that?
- regent
Not immediately; I will need to see if there is a workaround (like for the SRI Reset) or if this is to be done with VIDA DiCE only. I am almost positive that software re-load will be required, and this will involve a VIDA subscription (i.e. a visit to the stealership).
Give me a couple hours to get back to my home office and look at my VIDA; your car is still operational, right
2015 BMW 335i
2015 BMW 335i
- regent
In the interim, here is a remote programming "workaround" procedure found on this forum:
https://www.matthewsvolvosite.com/forums ... 2&start=14
Credits: MadeIn Japan
Before you do it, you may want to make sure your remote has a good battery.
Hope this solves your problem
2015 BMW 335i
2015 BMW 335i
Madhelpermonkey
Car works fine its just that the two step unlocking ceased to work. I think it important to mention that i replaced the drivers door lock assembly with a bone yard unit after the original broke. A plastic part in the key way broke.
- regent
Did you try the suggested re-programming steps above?
2015 BMW 335i
2015 BMW 335i
Madhelpermonkey
not yet somehow I missed the post will try tonight
Thanks for pointing that out.
Madhelpermonkey
no change in operation one push on remote turns on interior light but doesnt unlock anything second push unlocks all
- regent
Activating internal lights on first unlock push indicates that the system acknowledges the command. It must be the control module's fault (the one that came with the lock assembly you got from the boneyard and put in earier), no?
2015 BMW 335i
2015 BMW 335i
- 733 Views
Last post by banjoman
- 4382 Views
Last post by WA-Boater
- 3484 Views
Last post by polskamafia mjl
- 983 Views
Last post by Dalpatine
- 1227 Views
Last post by Window_Licker
