Can one acquire a VIDA / DICE DVD ? (or is it vadis)
fazool
Year and Model: S60, 2007
Been thanked: 7 times
Post by fazool »
I see a lot of value in the diagrams and repair instructions coming off the VIDA system.
I see VIDA dvd's on eBay and wasn't sure if one can just buy these and install them.
DO they need to be registered with Volvo in order to work? Are these legit or are these black-market discs?
I don't want the diagnostic tool and am just interested in the PC software.
Any thoughts?
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
Mine is 2010A from alibaba.com; came activated (no internet required). It came with the DiCE (which is a CARB modem with a USB output) and you can do everything except for software reload, which will require paid subscription and authentication 'as a shop' over the Internet. So far it has paid for itself about a dozen times (the price I bought it for was $165 delivered, which equals 1.83333 trips to the stealership.) I have it on a dedicated machine running WinXP SP2 with IE8. Installation on Win7 may be possible, but I have not had time to play with it.
If you have a reliable cable and a 'thingy' that can translate from CARB-ish to USB-ish both ways, then you may skip the DiCE.
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
regent
Post by regent »
On another note, the VIDA can run standalone without the computer-to-car connection.
If you do not need to 'talk to the car', you can just run VIDA to look up diagrams, part numbers, procedures, etc.
2015 BMW 335i
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
I couldn't get it to work on Win7 64-bit. Apparently it will work on 32.
'98 S70 T5
2016 Chevy Cruze Premier
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
UK seller norrisuls sells a nice working copy which works fine on my XP with IE8 setup: http://www.ebay.com.au/itm/180790888139 ... 1497.l2649
Don't you know; everything is legit on eBay :wink:
His copy also comes with a wiring DVD: great value at around $15!!
As far as the Alibaba sellers stay away from Shenzhen Digiobd Electron Technology Co., Ltd.
Their DVD won't allow sign-in and the Dice diagnostic unit I bought from them is faulty.
fazool
Post by fazool »
I may have used the wrong name.
I think I was looking for VADIS (the aftermarket version).
Do I understand correctly that VIDA is the SW to communicate with DICE and VADIS is the standalone afgtermarket?
Too many acronyms E-I-E-I-O
So, ammending my question:
Can I buy just VADIS or do I have to register that? I read mixed things and got the impression some are bootleg and need to be registered etc.
Is it only available to shops?
regent
Post by regent »
I have had an 'eBay-VADIS' for several years now as well; came on a DVD with install procedure and admin credentials - no registration required. Includes MY up to 2005 (I believe).
Great quick-reference source for component diagrams, torque specs, part numbers, and procedures (some of the PNs may have been superseded though) but still searchable.
I have run it on 32-bit WinXP SP3 and Win7 machines.
2015 BMW 335i
jblackburn
I downloaded VADIS through a torrent. Setup instructions are a bit confusing, but after it took like 2 hours to install, I've had it on my work machine (XP 32-bit) for over a year. It's really helpful for some things and totally useless for others. It's VERY hard to find certain things in.
'98 S70 T5
regent
Post by regent »
Be careful with P2P file transfers, there is too much malware in the wild. Some of the downloads are infected with malcode that can be costly to hunt and remove 8)
2015 BMW 335i
fazool
Post by fazool »
yes, I dont need a bootleg or shared copy - I am trying to find out how to buy a legit real copy if its not too expensive.
