How to Fix a Broken Signal Arm
Fish stick88
Year and Model: 1994 - 850 Sedan
Post by Fish stick88 »
A week ago my car's turn signal arm broke off. I ordered a part from Volvo Wholesale (which I found to be the cheapest site.)
It cost me $80 for the unit, (because I had cruise control, which most people do)
Anyhow, a relatively easy fix. It didn't take me long at all. I did "jimmy rig" a temporary fix for the signal as I was concerned about my safety (moreso how dumb other drivers can be...)
Here it is! Comments welcome.
Aj
Locate the shroud. (If you can't, Quit now.)<br />Take out the 4 screws at the bottom (T15)<br />Make sure the steering wheel is straight ahead, if it isn't already. <br />Extend the wheel all the way out, and down, take the top portion off.<br />Put the steering wheel up, take off the bottom portion, careful of the ignition cylinder, it should come off after some moving around
Steering Shroud.png (66.73 KiB) Viewed 2424 times
Next, remove these two bolts, the bottom one has a ground wire on it, make sure you don't for get it when you are re-assembling.
next, remove the two electrical harnesses, and take the unit off, I took mine off, and temporarily replaced it with a screw driver, and when you get the new one, re-assemble in reverse.
If anything from this project, i've learned, and have been reminded of how hard Volvo makes it to get things apart, I struggled with these wires for what seemed like ages.
Well done Volvo.
Well done.
Hope this helps, AJ
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
AJ, nice tutorial. I'll add this to the repair database.
Also -> Amazon link
Fish stick88
Thanks, I know its not much, but at least the "no experience members" now have something to build off of.
I hate to see or hear people giving all their money to the stealership!
