1997 Volvo 850 Base Air Pump and Air Pump Relay to be tested
sothernmech
Year and Model: 850 GLT 1995
Post by sothernmech »
Good night you all !!!
Does any of you know how to test these parts:
1- 1997 Volvo 850 Base Air Pump. I got an used in mint condition-exterior- but not tested
2-1997 Volvo 850 Base Air Pump Relay. It comes with the pump but the seller does not know how to test them but said to be working. I prefer " trust but verify" .
Thanks in advance for your help.
osman
Year and Model: 2002 c70 hardtop
Post by osman »
bench test with 12v/
on the relay the largest prong is the pos and the center prong is the ground
Brick Life
2003 Saab 9-5 ARC V6 3.0 Turbo 120K SwagWagon
97 850R wagon mileage unknown
2000 C70 Turbo Convertible 110K
99 XC70 AWD LPT 115
98 BMW 328IS 130K M3 Wheels
94 Mercedes 420E 160K
Kiwi bluetooth/Torq Pro app VOL-FCR/VAG-COM USB cable
sothernmech
Thank you osman for you help.
sothernmech
osman
Post by osman »
Usually i find that both the fan and or the relay are working and for one reason or another its just not turning on.
Its only supposed to turn on during cold starts and even then only for a minute or two.
Brick Life
99 XC70 AWD LPT 115
osman
Post by osman »
Brick Life
99 XC70 AWD LPT 115
Has thanked: 312 times
Been thanked: 818 times
Easiest way to solve this is to do the SAS delete.
Some people like to keep their car stock and I can appreciate that. But SAS is an emissions control system that was used briefly on these cars, then abandoned. You are not hurting the car or the outside or anything else by eliminating it. A $2 diode, a wire connector or some solder and 20 minutes of your time, and you are done with it forever.
http://volvospeed.com/install_performan ... -pump.html
