Re-routed PTC-to-intake manifold vacuum line with Gates 3/8ths inch tubing.
Re-routed vacuum tree-to-fuel pressure regulator with Gates 3/8ths inch tubing.
1997 850 T5
Forum rules
- Has thanked: 2857 times
- Been thanked: 1332 times
Since replacing/re-routing the vacuum lines, my persistent P0422 has given way to a P0420 (twice).
P0440 yesterday @ 42 miles. Reset.
Bosch rotor (Bosch #04272) and cap (Bosch #03371) installed.
Air filter cleaned in mild soapy water.
Battery disconnected.
Cleared "half a code" after nearly 200 miles with nothing set. Started thinking what to call this... settled on "pre-code".
Castle Rock round trip 30.5 mpg. Light traffic, 70-75 avg mph.
Castle Rock round trip 30.5 mpg. Light traffic, 70-75 avg mph. Same as above.
Pre-code @ 35 miles. Reset.
Just hit 110k miles.
Castle Rock round trip, 30.8 mpg.
Topped up trans fluid.
200+ miles with a pre-code, ugh. Half boost is killing me. Will clear it either way after next trip. Not affecting MPG, fortunately.
Next parts order: tie rods (TRW), axle seals and lower engine mounts.
To do:
-install the above
-trunk struts
-oil return line gasket, o-ring
-remove headlight wipers
-redo control arms - tightening bolts at ride height this time
-replace fuel filter
-tighten RF strut nut
-Seafoam
-alignment
To do:
-install the above
-trunk struts
-Seafoam
-alignment
Fuel filter yesterday. No problems. 110,200 miles.
Installed MBC
Cleaned spark plug carbon
Gapped SPs to .026"
Two turns on wastegate
Cleaned MAF
Making up to 14psi
Installed MBC
Gapped SPs to .026"
Cleaned MAF
Making up to 14psi
Yesterday:
new outer tie rods
installed second set of used orange injectors that I'd soaked in isopropyl alcohol
1.5 turns wastegate
boosting to 15psi
Seafoam - 1/2 through intake, 1/4 in oil, 1/4 in gastank
new outer tie rods
1.5 turns wastegate
boosting to 15psi
