What has failed on your 1992-2000 FWD or AWD Volvo?
02 sensor
150
2%
a/c clutch, compressor, accumulator tank
89
1%
a/c evaporator, purge valve, pressure switch
54
1%
a/c receiver-drier
21
0%
ABS module
246
4%
airguide, skidplate
63
1%
alarm status indicator
13
0%
alternator
80
1%
ball joints
142
2%
battery cable
43
1%
bevel gear
19
0%
brake booster check valve
5
0%
brake caliper
84
1%
brake hoses
54
1%
cabin temperature sensor
26
0%
camshaft position sensor
49
1%
cargo cover on wagons
22
0%
center arm rest, release
50
1%
center hood latch, extension lever
37
1%
control arm
113
2%
coolant expansion tank, cap
112
2%
coolant hoses and clamps
91
1%
crank seal
23
0%
crank sensor
11
0%
cruise control, linkage at the gas pedal
26
0%
cup holders
170
3%
cv boots, axles
184
3%
dash ungluing
96
1%
defroster plate
12
0%
door catch, check strap, hinge
123
2%
door lock actuator
100
2%
door panel ungluing
122
2%
door-lock switch
54
1%
driveshaft
41
1%
ECC electronic climate control
46
1%
ECT engine coolant temperature sensor
54
1%
ECU air tube
34
1%
emissions air pump SAS, relay, valve
64
1%
engine mounts
213
3%
ETM
61
1%
exhaust hanger
59
1%
FPR fuel pressure regulator
10
0%
front washer pump
11
0%
fuel door latch
54
1%
fuel pump, relay
53
1%
glovebox lock
44
1%
grill retaining clips
25
0%
head gasket
24
0%
headliner ungluing
80
1%
heated seats, seat t-stat, seat wiring
70
1%
heater core, blower, resistor, lines
155
2%
IAC idle air control valve
17
0%
ignition coil, coil pack
67
1%
ignition switch, cylinder
50
1%
interior light dimmer
9
0%
interior switch, info switch
24
0%
keyless entry, remote or car
64
1%
MAF mass airflow sensor
123
2%
odometer gear
109
2%
outdoor temperature sensor
16
0%
parking brake cable
68
1%
PCV system
179
3%
PNP switch
40
1%
power antenna, cable
83
1%
power door locks
53
1%
power steering pump
18
0%
power steering rack
43
1%
power window module
27
0%
power window motor
20
0%
power window switch
75
1%
radiator
144
2%
radio, cd changer
58
1%
rear hatch latch
35
1%
rear main seal
47
1%
rear washer pump
42
1%
seat adjustment switch
33
1%
seat belt release
36
1%
seat cable
20
0%
seat leather, cloth surface
133
2%
shift solenoid
16
0%
shift-lock microswitch
40
1%
signal flasher relay
9
0%
speakers, speaker wires
63
1%
spring seats
67
1%
starter
40
1%
steering wheel
15
0%
strut mount
136
2%
sun visors
52
1%
sunroof
43
1%
sway bar link, end link, tie rod
152
2%
tailgate or trunk strut
126
2%
thermostat
101
2%
throttle control linkage
9
0%
timing cover seal
7
0%
transmission
42
1%
turbo oil cooler line, oil return, gasket, o-ring
69
1%
vacuum lines, elbows
145
2%
wheel bearing
93
1%
windshield washer tank
20
0%
windshield wiper arm, post
48
1%
Total votes: 6508
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
What has failed on your 1992-2000 FWD or AWD Volvo? That includes the entire 850 and S70 family, and XC70, C70 and V70 models up to model year 2000.
2001+ family failed parts poll is here.
I will have an S80 poll in the S80 forum, and an XC90 poll in the XC90 forum soon.
Wait... There's More
P80 - How much do you spend on labor per year?
P80 - How much do you spend on parts per year?
You can come back to add parts as the years and months go by. You can vote not for one or two of these choices, but for every one of them, if you're that unlucky.
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
[Fixed a setting that only allowed one vote]
Also -> Amazon link
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
Just to add to the list as it's missing the Info Switch failed but I managed to repair it and refit the original, and the front headlights had to be changed as the reflectors were shot - Mike
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Didn't see starter as an option.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
matthew1
Site Admin
Post by matthew1 »
I'll sneak those in via direct database query. Look for them to be appended to existing entries because I reached the max (!) 100 entries.
Tie rods also.
Thanks guys!
Also -> Amazon link
Ben850
Been thanked: 7 times
Post by Ben850 »
How can we add to the list after we already hit submit, but may have forgot to vote on an item? (or more)
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
matthew1
Site Admin
Post by matthew1 »
You should be able to go in again and again and check more boxes. Reply back if you're not able to.
Also -> Amazon link
Ben850
Post by Ben850 »
No. The first time I clicked on the thread the boxes were open to check, or you could click see results. Now there is no longer an option, just results.
matthew1
Site Admin
Post by matthew1 »
Your vote came before I discovered I'd set the poll incorrectly, and you're getting locked out. I had no idea that would happen until now. Well, let me do some digging and I'll see if I can reset your vote. Might be a few days. Sorry about that.
Also -> Amazon link
Ben850
Post by Ben850 »
Oh, not to worry. By then I'll have an accurate assessment of what I've replaced. Being a '93, it probably had some prototype parts that were still being refined but deserve to be accounted for.
