v70 timing problem
Myk2l
Year and Model: V70 2.4 T5 2005
Post by Myk2l »
I have changed the water pump on my 2001 v70 2.3, unfortunately the cam sprocket and crankshaft have been moved. How can I ensure that they are re-set correctly?
JDS60R
Been thanked: 3 times
Post by JDS60R »
Does your camshaft pulleys have VVT ( Variable valve timing) or are they regular metal pulleys?
Retired
JDS60R
Post by JDS60R »
I can also see two 2.3T motors . Can you give me the motor number off the side cam cover please ??
Retired
JDS60R
Post by JDS60R »
Here are the two 2.3L turbo motors cam belt procedures. There is a T7 and a T3 variants
B5234T7 cam belt.pdf
(403.86 KiB) Downloaded 199 times
B5234T3 cam belt.pdf
(403.71 KiB) Downloaded 288 times
Retired
Myk2l
Post by Myk2l »
the engine is a B235T and not vvt
Myk2l
Post by Myk2l »
I have marked the two camshaft pulleys, if the marks are aligned separately are they sure to be in sync?
JDS60R
Post by JDS60R »
3 marks are necessary or damage will occur
2 cams and 1 Crank mark must be in the correct position before installing the belt.
Retired
JDS60R
Post by JDS60R »
The cams are already marked and you should use the Volvo marks
Retired
JDS60R
Post by JDS60R »
Are you saying that B235T is on your side cam cover. I see no listing for this motor in the US or UK market.
Retired
Myk2l
Post by Myk2l »
Sorry, it's dark here and I tried from memory engine is B5234 T
