P80 -1998 serpentine belt tensioner tool tricks DIY
Serpentine Belt Tool DIY
guambrocha
- Year and Model: 1996
Found a post from someone else on how to make a serpentine belt tool. For a 1.99$ get a pipe cap, grind it with a metal grinder ( duh
) and then drill a hole through the thread area and use a metal bar to give it some force, I used a big drill bit i had around my garage. It worked just fine. Thanks to the person who came up with this idea, just thought I would spread it and save you 30 dollars as someone else did to me.
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
Sweet idea! Now all I need is a grinder
You could make some beer money if you made a bunch and sold 'em - and I'd be first in line!
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
- Has thanked: 311 times
- Been thanked: 817 times
Excellent, time for another serp tensioner tool debate! Well you can be sure of one thing, there are at least 5 or 6 ways that are definitely better than all the others.
- Been thanked: 504 times
No need to drill the hole.
1. Grind opposite sides of the threads flat with either:
- Bench Grinder
- File (yes you can file by hand)
- Belt Sander (turn the belt sander upside down for ease of use).
2. Then use this tool with an adjustable wrench.
It works every time for me.
And the fit is perfect in that square hole.
Here is what it looks like. Hope this helps:
- Bench Grinder
guambrocha
thank you for sharing the original idea. very much appreciate it
I guess i didnt have to make the hole hehe
My preference over both filing and drilling a hole: screw a hex fitting on there, then you can use a regular box or open end wrench on it.
MilehighV70XC
- Year and Model: '99 V70XC, 143,000mi
Am I missing something? Is there really a need for a special tool? Just changed mine last weekend. I used a double closed end wrench (12mm?) pulled it clockwise to release tension, and then used a bungee cord like strap through the end to hold it in place while a changed the belt.
TheBraveOne
- Year and Model: Volvo C70 2011
Hello there. I do apologize if my post here is quite late. The topic here caught my attention. Great idea right out there mate. Saving 30 dollars is a big value for me. I've been looking for more info about serpentine belt and fortunately I found this one. Any updates for this? I might try that idea next week. I hope I can do it.guambrocha wrote:Found a post from someone else on how to make a serpentine belt tool. For a 1.99$ get a pipe cap, grind it with a metal grinder ( duh) and then drill a hole through the thread area and use a metal bar to give it some force, I used a big drill bit i had around my garage. It worked just fine. Thanks to the person who came up with this idea, just thought I would spread it and save you 30 dollars as someone else did to me.
- 3105 Views
Last post by jreed
- 22 Replies
- 35917 Views
Last post by erikv11
- 1388 Views
Last post by Faust
- 1065 Views
Last post by mrscullini
- 30 Replies
- 4929 Views
Last post by regent
