What has failed on your 1992-2000 FWD or AWD Volvo?
02 sensor
150
2%
a/c clutch, compressor, accumulator tank
89
1%
a/c evaporator, purge valve, pressure switch
54
1%
a/c receiver-drier
21
0%
ABS module
246
4%
airguide, skidplate
63
1%
alarm status indicator
13
0%
alternator
80
1%
ball joints
142
2%
battery cable
43
1%
bevel gear
19
0%
brake booster check valve
5
0%
brake caliper
84
1%
brake hoses
54
1%
cabin temperature sensor
26
0%
camshaft position sensor
49
1%
cargo cover on wagons
22
0%
center arm rest, release
50
1%
center hood latch, extension lever
37
1%
control arm
113
2%
coolant expansion tank, cap
112
2%
coolant hoses and clamps
91
1%
crank seal
23
0%
crank sensor
11
0%
cruise control, linkage at the gas pedal
26
0%
cup holders
170
3%
cv boots, axles
184
3%
dash ungluing
96
1%
defroster plate
12
0%
door catch, check strap, hinge
123
2%
door lock actuator
100
2%
door panel ungluing
122
2%
door-lock switch
54
1%
driveshaft
41
1%
ECC electronic climate control
46
1%
ECT engine coolant temperature sensor
54
1%
ECU air tube
34
1%
emissions air pump SAS, relay, valve
64
1%
engine mounts
213
3%
ETM
61
1%
exhaust hanger
59
1%
FPR fuel pressure regulator
10
0%
front washer pump
11
0%
fuel door latch
54
1%
fuel pump, relay
53
1%
glovebox lock
44
1%
grill retaining clips
25
0%
head gasket
24
0%
headliner ungluing
80
1%
heated seats, seat t-stat, seat wiring
70
1%
heater core, blower, resistor, lines
155
2%
IAC idle air control valve
17
0%
ignition coil, coil pack
67
1%
ignition switch, cylinder
50
1%
interior light dimmer
9
0%
interior switch, info switch
24
0%
keyless entry, remote or car
64
1%
MAF mass airflow sensor
123
2%
odometer gear
109
2%
outdoor temperature sensor
16
0%
parking brake cable
68
1%
PCV system
179
3%
PNP switch
40
1%
power antenna, cable
83
1%
power door locks
53
1%
power steering pump
18
0%
power steering rack
43
1%
power window module
27
0%
power window motor
20
0%
power window switch
75
1%
radiator
144
2%
radio, cd changer
58
1%
rear hatch latch
35
1%
rear main seal
47
1%
rear washer pump
42
1%
seat adjustment switch
33
1%
seat belt release
36
1%
seat cable
20
0%
seat leather, cloth surface
133
2%
shift solenoid
16
0%
shift-lock microswitch
40
1%
signal flasher relay
9
0%
speakers, speaker wires
63
1%
spring seats
67
1%
starter
40
1%
steering wheel
15
0%
strut mount
136
2%
sun visors
52
1%
sunroof
43
1%
sway bar link, end link, tie rod
152
2%
tailgate or trunk strut
126
2%
thermostat
101
2%
throttle control linkage
9
0%
timing cover seal
7
0%
transmission
42
1%
turbo oil cooler line, oil return, gasket, o-ring
69
1%
vacuum lines, elbows
145
2%
wheel bearing
93
1%
windshield washer tank
20
0%
windshield wiper arm, post
48
1%
Total votes: 6508
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
I think I checked over half of the things on that list. :shock:
'98 S70 T5
2016 Chevy Cruze Premier
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Poll options updated as per requests.
Also -> Amazon link
Ben850
Been thanked: 7 times
Post by Ben850 »
matthew1 wrote:Poll options updated as per requests.
I don't know if it is working for everyone else, but I still cannot add to the list. Maybe I permanently locked myself out by voting before the fix? It's alright, Just imagine about 3/4 of the list and a few that aren't on it.
Enjoy.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
rbrad6937
Year and Model: 850 Turbo 1996
Post by rbrad6937 »
gbaxa3
Year and Model: XC70 1998
Post by gbaxa3 »
Significant item missing, at least from my wallet's point of view, steering rack. Blew every seal on winter. Passenger front wheel bearing has failed three times in 10 years of ownership. Currently troubleshooting rear wheel, stay is broken, undetermined cable connection is sheared at splice near control arm. The joys of car ownership.
GB3
1964 P1800
1998 XC70
2012 C30
aahmes57
Year and Model: 1998 S70 GLT
Post by aahmes57 »
Pretty much alot. Bought it for $3200 and I have about $2000 (not counting any misc labor) in parts in it. PCV system, both cam and crankshaft seals, oil coolant lines, struts, ball joints, axles, tie rods, rotors, ABS module, heated seat switch, rr window switch, rear shocks, t-belt and associated components, drivers seat switch, and a few others that escape me at the moment. Runs great at 190,000 so I guess I'll keep it.
1991 740 (saved a life)
1998 S70 Turbo caught fire, very sad day
1995 850 sold
1999 V70 Base daily driver
mynorsyama
Post by mynorsyama »
Dashboard backlight
Horn switch
Radiator fan
Headlight switch
Internal Fan switch
Recirc valve
VTexan
Year and Model: 1995 Volvo 850
Post by VTexan »
Radiator.
Colonialgirl
Year and Model: S-70, 1998
Post by Colonialgirl »
I just had to have the Cam Shaft Seals replaced on my 1998 S-70 (Non-Turbo) I was losing oil there like crazy; Thought it was the PCV Oil Separator, BUT after replacing the seals, they checked the crankcase pressure and found ALL to be normal.
BTW, If you are around Tampa or Brandon, FL; Bergman's Foreign Auto Service did an excellent job at a reasonable price and were up front about what was needed and didn't add on to the costs.
Oddbob
Year and Model: 1995 854 Turbo
Post by Oddbob »
I forgot to check (1) shift-lock microswitch and (2) signal flasher relay for my 1996 850.
Other things:
  • Misc lights in the dash/radio.
    Backlight for PRND3L.
    Driver window button fell apart.
    Speed sensor at trans went in and out.
    Steering column cover secures broke.
    Horns died early on.
The Good - 1995 850 Turbo
The Eh... - 2004 Ford Focus
The Dead - 1996 850 GLT - The bane of the Grand Cherokee..
