It is visible to my untrained eye.
Is this the replacement part MVS recommends www.ipdusa.com/products/7355/112504-upper-engine-mount?
Any suggestion for the one on firewall?
Repairs never end :lol:
Cracking upper engine mount bushing, is it safe to drive?
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Sure, it'll just vibrate a whole heck of a lot.
See the instructions for replacing the mount - basically you need to saw out the old one and then freeze and lube up the new one with dish soap to press it in.
Check your lower "front" engine mount as well - you'll need to jack up the front, remove the right tire, and peel back the fender liner. Look for the mount to the right of the crankshaft pulley to see if it is ripped or collapsed.
'98 S70 T5
2016 Chevy Cruze Premier
xHeart
It does when in Drive. I can feel it on steering, and paddle. The cold start engine is louder and heavy for a minute or so, but then it quiets down to normal and crispier sound.jblackburn wrote:Sure, it'll just vibrate a whole heck of a lot.
This is what I think you are pointing to J, any sign of...?jblackburn wrote:Check your lower "front" engine mount as well - you'll need to jack up the front, remove the right tire, and peel back the fender liner. Look for the mount to the right of the crankshaft pulley to see if it is ripped or collapsed.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Those mounts look ok to me. You haven't seen torn. Here is a pic of a front mount that is bad. As for the upper mount, they tear clear through. That one has a while to go.
- rspi
Contact rspi..
Here is a bad upper mount:
JRL
- Year and Model: Several
- Been thanked: 16 times
Correct
That upper mount is not broken or torn in any way
- Has thanked: 312 times
- Been thanked: 818 times
A broken upper mount doesn't change much as far as vibrations transmitting to the cabin. The main difference when that mount breaks is it causes the engine to lurch back and forth on turns, makes the car feel like it is handling poorly.
And +1, those mounts look to all be in pretty good shape, for sure the upper one.
- Been thanked: 504 times
You have 3 options:
1. Volvo Mount (maybe made by Corteco or Lemforder, not sure).
2. Febi (I don't know much about reliability of Febi but Febi has a good name).
3. Polyurethane bushing.
I use the Poly bushing from IPD at 50K in 2003.
Nine years later still good.
There is however a very very very slightly more vibration at idle.
When driving, it is fine.
It does not bother me but may bother some people.
If so, then use Volvo mount.
cn90 maybe you saw the title but didn't actually read the thread?
That upper mount is totally fine, I wouldn't replace it.
Actually, the pic posted by xHeart showed some cracks already.
This happened to me in 2003, when I took the factory upper mount out, it broke a part.
Although xHeart mount does not look too bad yet, it can cause vibration.
- 875 Views
Last post by lext
- 754 Views
Last post by 454cid
- 956 Views
Last post by GreenMagicMan
- 928 Views
Last post by mouseskowitz
- 938 Views
