Forum rules
cmblackburn
Year and Model: 1998 S70 T5M
Been thanked: 7 times
Post by cmblackburn »
Feb 22, 2012 - 214,782 miles - Tires rotated/nail removed & tire patched
Dec 22, 2011- Tires rotated
Dec 21, 2012 - Oil change - 209,201 miles
-Fixed oil leak on cam cover
-Fixed radiator hose leak
Dec 15, 2012 - Heater hose blew/replaced
Oct 17, 2011 - 205,500 miles - Timing belt/water pump/camshafts/entire PCV system changed.
Sep 22, 2011 - Oil change - 204,000 miles
July 21, 2011 - Oil change - 199,000 miles
July 15, 2011 - 2 new Yokohama tires installed; 4-wheel alignment - 198,000 miles
May 19, 2011 - Oil change - 193,500 miles
May 12, 2011 - Transmission shift solenoids replaced; Mobil-1 ATF changed - 193,307 miles
Nov 26, 2010 - Replaced radiator (Nissens), heater core, and radiator hoses.
October 2010 - 180,000 miles - new front brakes/rotors, new LH hub bearing, and 2 new Yokohama tires
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
jblackburn
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
March 6, 2012 - 215,311 miles
  • Oil Change
  • Replaced brake booster vacuum hose
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
April 26 - 218,008 miles
  • Spark plugs changed - Bosch copper
  • Oil leak from cam cover bolts fixed
  • #2 spark plug wire replaced (drowned in oil)
  • K&N air filter cleaned
'98 S70 T5
jblackburn
June 17 - 219,000 miles
  • Replaced defective power steering pump w/ used unit.
'98 S70 T5
cmblackburn
jblackburn wrote:June 17 - 219,000 miles
Replaced coolant with Prestone
Repaired hole in upper radiator hose
Rotated tires
Replaced info, sunroof, heated mirror/window, interior light dimmer, and rear fog light switches with units refurbished by myself from junkyard
(May 7th) Replaced radio lights with bulbs from Radioshack
cmblackburn
September 29th-
-Replaced defective Duralast 47DL with new one- $52.00
-Re-positioned top PCV hose- was leaking slightly.
-Purchased jumper cables... :oops:
October 4th-
-Re-charged A/C with 12oz. can R134A from Ollie's- used about 3/4 can. $6.88
October 9th-
- installed Volvo tire stem caps.
- Put 2 "prancing moose" magnets on either fender from Dave Barton- $8.60
October 10-
-Replaced missing passenger side fog light grille with new OEM part- $14.70
-Installed iPd license plate frame- $2.00
-Filled tires to proper pressure(s), incl. spare.
October 11-
Replaced battery in transmitter #1.
October 12-
-Replaced missing screws for driver's side fog light- free.
cmblackburn
219,350-
-Replaced back brake pads with Volvo OEM, cleaned shims.
-Replaced oil (Mobil 1 High Mileage Synthetic 5w30) and filter (Purolator)
-Replaced old, green brake fluid (>5 years old) with fresh new dot 3, bled brakes until clear (4 bottles)
-Replaced older style Volvo emblem for new style ordered from Ebay.
-Filled low tires up, 36/38 psi. Were mostly down by 10 psi. Back tires have little to no tread remaining and will be replaced shortly; outer and inner tie rods are no longer any good; will be replaced with Volvo OEM and aligned.
cmblackburn
November 25,2012- 219,697
-Replaced upper heater hose with almost new part from junkyard
-Replaced cracked drivers side headlight lens with good used unit
-Replaced all coolant
-Installed wiring for model year 99 side marker lights
-Installed 1999 C70 windshield washer "fan" jets
-Put on "I <3 My Volvo" plate found in junkyard
volvo-repaired-I love my volvo.jpg (339.22 KiB) Viewed 12708 times
cmblackburn
11/28/2012-219,723:
-Heater coupler replaced
Heater core O-rings replaced with aftermarket silicone parts
cmblackburn
11/30/2012 219,732 miles- ALL cooling hoses replaced with 350 mile OEM Volvo replacement hoses from friend's totaled '98 V70 T5 :(
12/1/2012 219,745 miles- Inner/Outer tie rods, steering boots replaced with TRW parts/aftermarket boots
-2 new Continental DWS Extremecontact 205/55R16's on the back of the car; Discount Tire
-Front end alignment @ Merchants; almost killed the car and myself (they didn't tighten a lock nut) :evil: Realigned to within perfect specs for a 98 S70.
Car is back to Stage 0.
