Looks like Volvo has changed the position of the cabin filter on the 2010 S80.
Need advice on location and how to replace it.
Location of Cabin Air filter in 2010 S80
I think it is under the glovebox but there is no cover like in the 2009. To the left on the centre consol there is a cover that could be the cabin filter but I am just guessing and want to know for sure before I start removing parts.
If that is the location this particular piece has no torx screws so I need to know how to release the cover.
The cabin air filter is near the firewire inside the car. if you remove the lower panel (which is held in place with two T25 torx screws) and snap off the center console side panel (also pull back the carpet too), you will find the cover for the cabin air filter on the passenger side at the VERY front of all the HVAC stuff. There are three tabs for you to push off and the filter should be there. The filter is very flexible, because of the space clearance, you will have to bend and manipulate the old filter out and do the same for the new filter (i've seen the same kind of setup in a BMW E36).
1998 Volvo S70 T5 Auto
1995 Volvo 850 GLT <- RIP
- 1597 Views
Last post by 454cid
- 2137 Views
Last post by stephansvolvo
- 10 Replies
- 3901 Views
Last post by BEJinFbk
- 1576 Views
- 1303 Views
Last post by brunocerous
