Bad motor mounts are fixed but i still have a noise-->
my02xcsp
Year and Model: 1998 xc
Post by my02xcsp »
Sounds a little like a bad wheel bearing but cornering left or right doesnt seem to change the sound also i couldnt feel any play in the wheel bearings. Any ideas??
BTW this is my 98 V70 XC
thanks
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Propshaft still in? Is it definitely coming from the front of the car, or somewhere around the shifter area?
'98 S70 T5
2016 Chevy Cruze Premier
my02xcsp
Post by my02xcsp »
yes prop shaft is still in the car. Today i was clipping along on a curvy road and i did notice the noise was louder going around left hand turns so maybe it is a wheel bearing. ill jack it up and give the wheels a tug to see if there is any play.
my02xcsp
Post by my02xcsp »
also it does seem to be coming from the front of the car. you can feel it on your feet a little bit. kind of a wawawawa sound and a light vibration.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
You can post a video of it on youtube or somewhere and link it so we can here it.
my02xcsp
Post by my02xcsp »
I just checked the front wheels and there is no play in the wheel bearing. i supposed that doesnt mean i have one going bad it just may not be worn to the point you can feel the play.
Ill have to try the youtube video. Im not sure the sound will record because its not really that loud yet. i will give it a shot though.
jblackburn
I had a bad one and there was no play (since these are sealed units).
If it goes away during a hard swerve to one side, it is a wheel bearing for sure.
'98 S70 T5
charlyW
Year and Model: 97 855 T-5 CD
Post by charlyW »
Have you changed the mount by the timing belt ? I had a failure that sounded exactly as you describe turned out the mount had completely failed so the engine was sitting on the subframe.
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
my02xcsp
Post by my02xcsp »
yes, thats the mount i changed. it was completely shot.
my02xcsp
Post by my02xcsp »
Ok i took some video clips of the car on jack stands. its not easy to hear the noise clearly. any thoughts on the noises? links are below.
thanks all.
http://www.youtube.com/my_videos_edit?n ... 9xr4DJUO78
