How to replace lower motor mount?
How to replace Volvo lower motor mount
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
How do you know you have movement? Are the other mounts good?
washdup
- Year and Model: 1998 V70 T5m
All mounts were replaced last year (along with RMS) during a clutch replacement. I had noticed excessive rebound when driving over a speed bump in first gear, particularly right after the rear wheels come down off the bump at very low speed; the car just rocks fore-aft a few times before settling down, and I can hear a metal-to-metal sound coming from somewhere; also, I did this with the hood open and a friend observed that the engine rocked excessively. Then we applied hand pressure to the top of the engine and could rock it --for comparison checked amount of movement the same pressure produced on another car of the same year, and it was much less. While one was pushing the engine, I could see that the rubber component of the front mount was allowing the movement. Poking the rubber, it seems softer than the one on the other car as well.
- Been thanked: 504 times
For those of you who have replaced the Passenger Side Lower Motor Mount:
- What were the symptoms?
- What mileage when yours went?
- rspi
Contact rspi..
Most of us just seen that it was torn. Inspect it yearly and change it when it goes bad.
RedHotT5
- Year and Model: 2000 C70
Sorry to wake up an old thread, but I have a question, I have a 2000 C70 T5, and I’m replacing the offside lower arm (right hand drive) and in the course of getting to the bolts, which go through the subframe, I believe you unbolt this engine mount and lift the engine in order to obtain access to the bolt which is obscured by the engine, is that correct? I know to use a block of wood on the Jack to lift the engine, any more tips from anyone?
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
I think the 00 C70 T5 are P80 chassis. If so... On my 1998 S70 T5 the mount completely collapsed so I had jack it up in order to remove the 2 side engine bolts before getting the sub-frame bolts.
- MoVolvos
RedHotT5
Also, by jacking up the engine, am I likely to break anything, this is the major concern for me right now, what should I remove or disconnect in order to prevent that? I’ve got 3 of the 4 arm bolts loose, just that one which is blocked by the engine to get, bit nervy as I’ve never attempted this on this car before.
- 10 Replies
- 2605 Views
Last post by darrylrobert
- 620 Views
Last post by Ozark Lee
- 18 Replies
- 6729 Views
Last post by Mark1967
- 1008 Views
Last post by pappatho
- 1284 Views
Last post by MadeInJapan
