What's the best headlight for 850?
Has thanked: 312 times
Been thanked: 818 times
1800ES wrote:I bought a new, complete passenger headlight assembly from the site below for $69.99. It is identical to the damaged one that was in the car. Shipping was quick.
http://www.lampsandlenses.com/epcgetspe ... =HEADLIGHT
This guy has been around for a long time, I have seen the site recommended on Volvo web sites for many years. That's your best bet, spare yourself the trouble and uncertainty of all the untested brands available on Amazon etc.
BKM98 S70 T5 wrote:-
... discovered the flaking and burnt reflector coating. Used the 90+ % alcohol to strip and degrease and then painted with Krylon Aluminum Paint of some kind. ...
I didn't say anything about it the last time you posted this story, but I will now because it seems a safety issue and is popping up again: I think painting the reflector on a headlight is a really, really bad idea. YMMV, you may be happy with it, but I wouldn't recommend it.
MoVolvos
Been thanked: 525 times
Post by MoVolvos »
Since I purchased the glass before I found out about the flaking and burnt reflective coating I thought I try the paint first. The Temp is way below the 200 degrees F of the Maximum of the paint. The Thermometer was inserted through a hole in the back of the OE Light Assembly. After comparing the results at night while driving and in another car I am OK with it's illumination performance. The worst that can happen is that it flakes again.
Just a follow-up: lampsandlenses sells factory spec headlights so you are good to go with those. But for anyone thinking about changing to some different type of headlights or bulbs, you can get excellent guidance with a good read through of Daniel Stern's web site. There is more to consider but his thoughtful and objective background information can serve as a good baseline.
http://www.danielsternlighting.com/home.html
ChiNorm
Year and Model:
Post by ChiNorm »
If you want better bulbs, I have been pleased with the PIAA.
