My Engine is Making a Weird Engine Noise (Video)
dfaulring
Year and Model: 1999 Volvo S80 T6
Post by dfaulring »
Hey! This is my first post here on this site. Pretty cool place :D
Anyways my 1999 Volvo S80 T6 is making a weird engine noise, I made a video.
Do you think you can tell me what's going on with the car? The car has been idling weirdly at low rpms and stalling at low speeds.
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
Has the car got an Electronic Throttle Motor or is it a manual cable, if its an ETM it could well be that on its way out, get the car scanned for any diagnostic trouble codes as a failing ETM usually throws a code (or two) - Mike
fn42
Year and Model: 98 V70, 00 S80
Post by fn42 »
I would say etm as well... you probably have a dead spot around the idle position. No check engine light?
if the ETM is ok it's most likely an airflow or metering issue. MAF might be a suspect (but since this is a T6 probably not? im not too sure how the T6 intake system works) or maybe intake manifold gasket or something stupid like that
