So I put my car up on ramps, took out the 24MM tranny drain plug (after having to run out to AutoZone to buy a wrench this big). I measured about 3.5 Qts on the drain. This sort of sounds ok. I replaced the 3.5 qt with 3.5 qt PEAK atf dexIII fluid and all shifts fine. The fluid I drained out was brownish but no smell, the drain plug (magnetic??) was very clean, no fuzz. I basically figure I'll do another 3.5 qt change in a couple of weeks when my regular oil change is due then maybe one more at summer's end. The tranny has never done anything strange so I am just going to stick with regular atf for now with drain and fills maybe every 2nd or third oil change. PEAK atf is only about 3.25 a qt through Amazon.
This all sound OK? I've put nearly 20K miles on the car since I bought it and am impressed with the lack of serious issues and the way the car stays fixed after fixing it. I am going after a 98 S70, NA, 140000 miles, asking price is $3100.00, probably gettable at 2800 cash. This is the same guy I got this one from. He seems to be pretty good with the Volvos.
Transmission Fluid change 98 V70
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Sounds like a great plan. No need for expensive fluid as long as you take care of it.
The transmission will thank you by living well past 200K like mine and many others with proper maintenance have done.
You hear about people blowing up the 4-speeds at 100-150K miles and I suspect it's because they've NEVER changed the fluid.
'98 S70 T5
2016 Chevy Cruze Premier
JRL
- Year and Model: Several
- Been thanked: 16 times
I would do them all now (within a few days of each other)
that way you will know when the fluid is thoroughly clean
Waiting that long in between drain and fills you can never know.....
KlubMarcus
- Year and Model: V70 XC, 1998
I have a 98 V70 XC and a transmission fluid change smoothed out the shifts.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I'm with JRL, do them within 50 to 100 miles of each other.
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
Go to this link half way down the page and click on the .PDF.
http://www.ipdusa.com/products/4808/107 ... h-hose-kit
With some 1/2 inch hose you can flush the entire system in one shot. As a quart or 2 gets pumped out of the transmission just add a quart or 2. When you start seeing clean fluid come out you know you are done. Follow the instructions on the PDF. I did it on my S70 at 100,000 and shifts great now. I bought a case (12 quarts) of transmission fluid from Sam's Club for $22.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
IPD is comfortable with the Trans Flush.shaker_chi wrote:Go to this link half way down the page and click on the .PDF.
The 12 quarts for $22 is a steal
Volvo S70 Upper Transmission Hose Removal. Green Clip w/O-Rings (sold as a kit see end of Video)
https://www.matthewsvolvosite.com/forums ... =1&t=32503
Metal Clip Shown Here in Full DIY Tutorial
https://www.matthewsvolvosite.com/forums ... f=1&t=8767
KlubMarcus
I want to use O'Reilly's Dexron VI ATF in my 98 V70 XC in order to avoid buying separate ATF bottles for different vehicles. Dex VI is compatible with older Dex IIE/III series that is specified in the owner's manual. What do you guys think?
KlubMarcus
Using this DIY guide www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=8767 I did an ATF drain and fill on my 1998 V70 XC. It was pretty easy to do. I took the plunge with O'Reilly brand Dexron VI drove it around the lot while changing through all gear selections. Will update if there are any problems or improvements. I'm not expecting anything to change with the auto trans, but you never know until you drive around for a bit.
- Used Valvoline MaxLife ATF, dark brown with a hint of red.
- CIMG1921 (800x448).jpg (155.2 KiB) Viewed 3971 times
- Use kitty litter and/or absorbent filler to soak up spilled ATF.
- CIMG1920 (800x448).jpg (238.48 KiB) Viewed 3971 times
- Turbo models need a flexible funnel to re-fill ATF due to intercooler piping. Dexron VI ATF is reddish-pink.
- CIMG1919 (448x800).jpg (213.81 KiB) Viewed 3971 times
- There's a small amount of debris that came out with the old ATF.
- CIMG1918 (800x448).jpg (175.65 KiB) Viewed 3971 times
- Eventually the gush of ATF will slow to a drip so you can re-install the drain plug.
- CIMG1916 (448x800).jpg (241.03 KiB) Viewed 3971 times
- The magnetic ATF drain plug had a lot of sticky gunk attached to it.
- CIMG1915 (800x448).jpg (193.13 KiB) Viewed 3971 times
- Used ATF will gush out hot, be careful and quick to reposition the drain pan.
- CIMG1917 (800x448).jpg (209.54 KiB) Viewed 3971 times
- ATF drain plug on the bottom right edge of the transmission case. Notice the crush washer, I re-used it.
- CIMG1911 (800x448).jpg (255.5 KiB) Viewed 3971 times
rmmagow
I ended up doing 4 drain and fills on my 98. PEAK dexIII atf fluid. Still shifts fine. In October I am going to do a mobil-1 ATF using the plastic hose method. This change will stay in there for at least two years assuming the car lasts that long. I did the Peak thing first because it was super cheap and I thought running a good load of new fluid before going the expensive Mobil-1 might be a good idea. Most likely too anal but I do like my old beast. Looks like I will put in a new propshaft in the fall as the car is holding up with nothing more than some evap/vacuum cels and a slightly flaky ABS computer.
- 16 Replies
- 3728 Views
Last post by fourteen2hands
- 16 Replies
- 3830 Views
Last post by - Pete -
- 1314 Views
Last post by V50M66
- 3428 Views
Last post by oragex
- 2874 Views
Last post by robrike
