Crazy headlight switch 2001 V70 2.4T
Draaz
Year and Model: V70, 2001
Post by Draaz »
So I am the proud owner of a used Volvo, my first one. It is a 2001 V70 2.4T and I love it except for one minor issue. the headlight switch is bipolar or schizo one. Sometimes the switch works and I can use my high beams, other times it is just the Day Time running lights and such. Time of day, weather, bumpy roads, it is purely random. I am hoping someone has heard of this and knows a solution. I have gone over the entire car for fuses and relays and everyone of them check out. Any assistance on this problem would be greatly appreciated.
Skip Isaacs
2001 V70 2.4T
Reason: Edited title for clarity.
steve850
Year and Model: XC70, 2004 and 2010
Been thanked: 3 times
Post by steve850 »
This is a US model, i take it?
Steve in Montreal
2010 XC70 3.2 N/A
04 XC70 2.5T
96 850 Platinum
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
The light switch is a module connected to the CEM, it is called the light switch module, LSM.
There may be codes related to it or communication with it in the CEM. The issue could be LSM or the CEM.
If the problem happens regularly then it will not be hard to find. If it is infrequent then it is much harder as it may check out all OK when things are being checked.
To start you could unplug the LSM and see if the irregular behavior happens when the LSM isn't connected. If it does then the wiring to CEM or the CEM are the things to check.
Draaz
Post by Draaz »
Steve in Montreal.... Yes it is a US model.
Jimmy57....... Thanks for the info. At least it is a place to start. I appreciate the info very much. I will reply if I find anything out.
Skip Isaacs
2001 V70 2.4T
keithatcpt
Year and Model:
Post by keithatcpt »
My us-model S40 has daytime running lights, so the lights are on anytime the engine is on. The light switch seems redundant except if I want parking lights only. But, if you leave the light switch in the "off" position, the high-beams don't work. This is a feature, not a bug. If you turn the switch to the "headlights on" position, the high beams work and the lights still turn off when I shut the engine off. Is it as simple as that? Maybe your headlight switch is flaky, making the computer think that the switch is in the off position intermittently?
2000 S40 184,000 miles
1999 Land Rover Discovery II (The Tank) 174,000 miles
steve850
Post by steve850 »
Operation is as keith said, but some years there were differences on canadian and us models. In 96 (and maybe later) there was a small screw next to the switch to disable the DRL's. This option was not available in Canada as we've had mandatory DRL's for years... I doubt you have the little screw, but it would be to the bottom right of the switch.
Steve in Montreal
2010 XC70 3.2 N/A
04 XC70 2.5T
96 850 Platinum
jimmy57
Post by jimmy57 »
Software replaced the little screw and the light switch is not a switch. It is a unit that sends via a digital signal to the CEM, the inputs you have requested by your turning of the knob, rolling of the light level control, and depressing of fog light buttons.
itllbemethen
Year and Model: V70 2000
Post by itllbemethen »
I maybe able to "throw some light" on this !
....and the previous writer provides the answer and the reason.
When is a switch not a switch ? When it's a module !
Had the very same problem with my V70. The "crazy" switch problem.
No main beam, always the same lighting configured, regardless of switch selection, no fog lights...oddly no centre consule radio/cd illumination either !
Then I found this.....
Hi,
I have some electrical gremlins with my 2000 (new shape) v70 - I am hoping that someone may be able to help track down whether it is the DIM or CEM I need to take out and fix!
Symptoms are:
-Start engine and instrument panel illumination stays off for several seconds before coming on (warning lights work as normal)
-Radio / CD player works but no display or backlights to controls
-Controls for climate control switches very dim
-No backlights on auto gear selector
-Instrument panel clock, odometer and message display very dim, but appears to work OK
-Headlight switch does nothing and appears to have no power - the daylight running lights are always on whether you select sidelights or night running and the main beam wont stay on in any setting.
The car runs and drives fine otherwise with no messages or warning lights.
From my search of the forum I suspect the DIM or CEM, but before I tear the car apart, which should I target first!?
At first I thought I'd written it myself !!!! Or he's stolem my car !
The answer he got was virtually a "one liner"
"Sounds like the light switch module !
We'll there ya go !
BillyBob
Year and Model: V70 XC 2001
Post by BillyBob »
Can this be replaced by average Joe driver? If so, how??
thank you! :shock:
packetfire
Year and Model: 2010 v50 2.4i
Has thanked: 17 times
Been thanked: 30 times
Post by packetfire »
I assume that the switch modules have been replaced by now, but for the record, one opens up the fuse access panel at the end of the dash, and one can then push the switch module out from behind. No screws, just a metal spring tab at the bottom of the unit. The single cable detaches easily.
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
