engine mount: does the bushing thread...
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
...into torque arm.
There is a visible tear, it is deep. Started the task which requires replacing the bushing. The torque rod is off, but removing bushing is difficult as hell, hand sawing the hardest rubber to loosen its grip. I am not close, but the back is killing me.
The new replacement bushing is sitting in the freezer.I have gathered clamps to squeeze it in, if I ever get there.
Any suggestion would be greatly appreciated.
TIA!
Has thanked: 311 times
Been thanked: 817 times
If you are asking for how to get the bushing out, the easiest way I have found is to hand saw it then yard on it with big pliers or vise grips etc. Not sure how that can cause back fatigue, can you explain? Sorry not sure how to help :(
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
He's right
Cut it first then whack it out, it comes out quite easily that way
xHeart
Post by xHeart »
Took a break, read your post. Felt better. Thank you!
It is out.
out in pieces...
out in pieces...
...smile!
without bushing...
without bushing...
Now the next is inserting the frozen bushing. Asking myself, if I have the energy?
preparing for next steps
JRL
Post by JRL »
You need a special press
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Last one I changed was with the iPd HD Poly mount. No press needed with that one.
xHeart
Post by xHeart »
JRL wrote:You need a special press
I was planning on using the pipe flange, washer, nut with a long bolt, and liquid soap as suggested in one of the MVS post JRL.
If there is a tool, would you point me to it? Would McKennaR lend me one?
I will have to wait a week to complete this job. My girls are off schools, I have work week ahead.
Many thanks!
JRL
Post by JRL »
I can't, dealer has it next door
It's just a press with the correct sized insert
xHeart
Post by xHeart »
rspi wrote:Last one I changed was with the iPd HD Poly mount. No press needed with that one.
Popular view at MVS favors rubber, many recommend rubber bushing Robert, therefore, replacing it with Volvo OE.
volvo parts being replaced
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Many thanks!
Using that method works fairly well. Freeze the bushing overnight and lube it with soapy dishwater before trying to install it.
'98 S70 T5
2016 Chevy Cruze Premier
