engine mount: does the bushing thread...
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
The recipe worked, but there is a problem.
The ring holding the bushing has move 1/8 in right. Do I pull the ring back, would it?
the ring holding the bushing has shifted
xHeart
Post by xHeart »
It is pulled over a bit, not centered.
view from driver side
Flush with the holding ring, little bruised.
view from passenger side
Should I try to center it, would it?
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Try attaching the upper firewall mount first and see how it fits in relation to this one before deciding what to do. The unit is for fore and aft movement so the side to side position should not make a whole lot of difference unless it is really off. As it is the mount is not intended to support the weight of the engine but to control movement and vibration.
xHeart
Post by xHeart »
It drives much better after replacing the two mounts.
But didn't want to not adjust the placement of ring, and busing.
Some modification which helped to restore.
using high school carpentry lessons
An acceptable completion.
98% back to factory placement - centered.
Thank you so much MVS!
