fading rubber/plastic trim on 850
duane
Year and Model:
Post by duane »
Does anyone know of a good product I can put on the black trim of my wagon? Ive tried a couple, Armorall ect but after a day it looks just as bad.
thanks
White850Turbo
Year and Model:
Post by White850Turbo »
Many people have had success with cleaning the bumper very well, masking the paint off, and using a couple layers of black Kiwi shoe dye. Make sure it's the dye and not the polish. It comes in a tall skinny container.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
bobsnow100
Year and Model:
Post by bobsnow100 »
Hello
I just recently painted my rear bumper which had faded pretty bad. I went to an automotive paint supply store and they have many different color bumper paints. They have a paint color sheet which you can put next to your car trim to match it really close. I first cleaned my bumper off with wax and silicone remover and then taped it off and sprayed it, looks great.
l33tDad
Year and Model:
Post by l33tDad »
This may be a dumb question, but are the bumpers supposed to be black or grey on a '93 850? I always thought grey, but maybe they're REAL faded or something. I'm going to try the shoe dye trick this weekend, but don't want to get the wrong color...
1993 Volvo 850glt
225,000 miles and counting
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I second the black shoe/leather dye by Kiwi...comes in a little bottle with applicator. Did my wife's '04 last year and still holding up. Use a rag and not the applicator...wipe as you go to keep streaking off of the paint. It's a bit hard to get off after it dries. You might need a second coat on the areas you can see has a lighter coat....good luck- go slow and you'll be happy with the results.
galerie
Year and Model: 1995 850 GLT
Post by galerie »
l33tDad wrote:This may be a dumb question, but are the bumpers supposed to be black or grey on a '93 850? I always thought grey, but maybe they're REAL faded or something. I'm going to try the shoe dye trick this weekend, but don't want to get the wrong color...
Mine are grey, I have a 1995 850... I bought this bumper dye from IPD and put it on this past weekend, looks a lot better but will probably need 2 more coats. I wanted to keep the same color grey on the bumpers/trim. I didnt wan't black which is what the kiwi dye will do.
http://www.ipdusa.com/ProductsCat.aspx? ... RootID=629
cosmicdust
Year and Model:
Post by cosmicdust »
Hey, I'm going to the store right now!
My '99 Black Beauty needs a pick-me-up!
1998 V70 AWD/GLT Turbo
io
Year and Model:
Post by io »
There's a product made by Mother's called "Back to Black" (small red bottle). It's for restoring fading rubber and plastic bumpers and trim. I tried it on the fading roof trim strips on S70 and it worked well. BTW, you can use it on trim pieces that are colors other than black. I'm in Canada and I bought it at Canadian Tire - a home improvement / hardware store but you can probably get it at most stores that sell Mother's products.
Nick
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
If you want to do it RIGHT and a job that it will last, re paint them with bumper paint.Comes in spray cans and it the correct color gray/black.
The longest part of the job is to carefully mask everything off, scuff with a scotch pad, (if a black product or anything else was used, also use some thinner to make sure it's off) then spray a couple of THIN coats.
The actual apint time won;t be more than 5-10 minutes. Your rub strips and bumpers will look almost brand new and will stay that way for years
chax
Year and Model:
Post by chax »
This isn't permanent, but will last a week or more: rub peanut oil on bumpers/trim. It's available at most grocery stores. I tried Mother's "Back to Black:" almost no change. Armor-All only helps a little, and not for long: just makes your faded plastic shinier.
