Severe Coolant System Issues '99 S80 2.9L Non-Turbo
elmo_allen
Year and Model: 1999 S80 2.9LNT
Post by elmo_allen »
Hello again,
The last time I was on here I had throttle issues, those have recently been resolved, however a new problem has popped up. When I purchased the car, in 2008, I only had to put coolant in it maybe one a year if that, and now I have almost gone through an entire bottle of antifreeze in about 2 weeks. I know I have a severe leak coming from the coolant tank, however I am not sure what all I should replace and what to do with the coolant that is in my tank and hoses.
There are two hoses that are coming off the coolant tank, one I know is the Expansion Tank Drain Hose, the other one goes into the fire wall. What is this hose and should I replace that one as well?
Also, where should I get these parts and would you recommend an aftermarket tank or a Volvo tank. There is about a $25 difference. I am thinking getting the Volvo tank.
If it would be easier below are some photos that I took of the area.
This is where the two hoses connect to the coolant tank.
This is a picture of the hose that goes into the firewall.
Proud Owner of a Silver 1999 Volvo S80 2.9
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
My suggestion for you is to go Volvo. Some of us enjoy taking a chance from time to time to experiment with After Market parts due to pricing and or not fearing having to do the work again. Also, it is difficult to say whether you absolutely need to change those hoses or not but if it looks like a difficult job and the hose ends look pretty bad you may want to do it once and not have to worry about it again. Coolant is not cheap and for some reason I've never like to play around with that Fluid.
http://eeuroparts.com/Parts/PartResult. ... egory=1007
EDIT: Drain the coolant in the Expansion Tank via the Radiator. There should be a petcock of some sort under the Radiator to remove all the Fluid before you begin.
elmo_allen
Thank you so much for your response.
I forgot to mention that there is a little bit corrosion at the end of the hoses that connect to the expansion tank, how do I clean the hoses properly?
Thanks again!
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Follow the large hose off tank bottom more carefully. It does not go to firewall, it goes to a pipe behind cylinder head. The grey pipe into firewall is for cool air to go to the computer box that is in front of your p/s reservoir and coolant tank. The black hose in that photo is the p/s hose.
elmo_allen
Ah ok. Sorry if that sounded confusing. I was trying to describe the cooling hose that goes to the computer. :D I did not know where it went to on the other end because it looked like it was going into the expansion tank. I saw where the other one went to, but thank you for clearing that up! It is one less part I have to get. :twisted:
Just out if curiosity do you happen to know how to clean the corrosion off of the hoses?
Thanks!
boosted5cyl
Post by boosted5cyl »
The aftermarket one would probably be fine for the remaining time you plan to keep the car. Check to see if it includes a level sensor too as that will affect the cost of course. Replace the cap too.
I had a leaking expansion tank and what made is super great was the fact that not only did the level sensor stick on top but the tanks was stained mid way as if the level was correct. I think this may have lead to the demise of my turbos.. Who knows.
Anyway, replace the tank and cap, its a simple job. One electrical connector, large pipe on bottom, small one on the top.
MoVolvos
Post by MoVolvos »
Thanks!
Depending on the condition you either replace it or cut it off. Many may not agree with me but if there is room and the hose is in decent shape I frequently cut a little section off as the hose (any hose) has been enlarged. This way as you push the hose back on there will be a section that is narrow and snug for the clamp.
elmo_allen
Ah good tip boosted5cyl. Thanks for the advice. I will take a picture of the tank tomorrow so you can see what it looks like. I am about 95% sure it is the tank. I think my leveling sensor is ok because it is letting me know when the coolant is low. Do you think I should still replace it?
Also thanks BKM for your advice as well. I think if I take a picture of what I am talking about, maybe you could tell me exactly where to cut it. :D. Also you can see how bad the corrosion is. It might not be as bad as I am thinking. :D
Thanks again everyone for your help, it is much appreciated! :twisted:
elmo_allen
Here are the images of the tank that I promised to show you.
MoVolvos
Post by MoVolvos »
First replace the cap and see if the car overheats as the coolant seem to be coming out from there. The tank is dirty but seems OK. Replace if you think it is old, brittle with fine hairline cracks. If you have slack on the hose cut a quarter to half inch off the end and reattached with a standard reusable hose clamp. If this solves the problem then flush the system as it seems to have had more rusty water than coolant sometime in the past. Another possibility is Thermostat or Head Gasket.
How To Fix An Overheating Car
