S80 a/c fan continues to run
surfdex45
Year and Model: 2000 S-80
Post by surfdex45 »
I have a 2000 S-80 non-turbo with 148,000 miles. When I turn off the car after using the a/c the fan continues to run blowing air into the passenger compartment. This occurs even if I turn off the a/c before exiting the car. It typically runs for 10 minutes or so before stopping. Any ideas?
Reason: Edited title for clarity.
yuckuJackD
Year and Model: XC70; S80; S40
Post by yuckuJackD »
It's OK. Don't give so much attention to that. Mine is running too.
Other thought: 50 minutes after shutting down the engine, if te ECC i left to auto the fan for the interior starts working on it's max speed for aprox 7 minutes. That's OK, too. The reason is that this way the pipes dries out preventing the system from microogranismus and the bad smell, you know.
GOOD LUCK
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
paramedic7829
Year and Model: S80 T6 2001
Post by paramedic7829 »
I have 2001 s80 T6 and that is a normal fuction as was said earlier it comes on after 50 mins after key is removed just climate control doing its job. Read your manual it will explain it.
