Second hand Airbag Module
D4v1dz
Year and Model: S60 2007
Post by D4v1dz »
When I replace the airbag module with a second hand airbag module, What program do I download from VIDA to make it work. The ECU i believe but I want to make sure.
D4v1dz
Post by D4v1dz »
To get rid of the code SRS-00DA
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
SRS reload on the software list.
Do you have VIDA subscription and legit VIDA?
D4v1dz
Post by D4v1dz »
I just bought the 3 day vida subscription and they are sending me the disk. I have clone dice, but i read those work just fine. so its called "SRS Reload"?
jimmy57
Post by jimmy57 »
Yes, alphabetical on the software drop down on the software page. SRS reload is the complete software package and any mating software for that system including software upgrades, if any.
I have only used non-dealer VIDA one time and I'm sketchy on the steps and how it is billed to credit card.
Once the software is downloaded and shows available you can then start loading it. The buttons you will have to click will be on the middle, btm left and btm right on various screens, not consistent huh? When you go through the steps follow any instructions on the screens. The ignition switch remains on for the download. The download process is very sensitive to over and under voltage. The best you can do without a regulated 30+ amp power supply is to use jumper cables and another car(or another loose battery) and a battery charger. The second battery provides a lot more stability and reserve. Turn your headlight switch to park position. The car will go dark a few times and lights will go off then on and relays will click. Then for the actually load it will stay dark for that step.
D4v1dz
Post by D4v1dz »
wow sounds so complicated. Will try it monday or something. Thanks, and your 100% sure that I need the "SRS reload" to make a second hand module work with my ECU, and to get rid of the SRS-00DA code?
jimmy57
Post by jimmy57 »
Yes, only two srs softwares available at most, reload and upgrade. Reload is the complete one and would include any related software for other associated modules.
Why are you replacing the module?
D4v1dz
Post by D4v1dz »
Because the original seems fried. It just doesnt detect the OWS and wont calibrate it.
jimmy57
Post by jimmy57 »
OWS module or its communication wiring to SRS module would be my first attempts. No wires knocked loose from OWS module under the RH seat?
D4v1dz
Post by D4v1dz »
jimmy57 wrote:OWS module or its communication wiring to SRS module would be my first attempts. No wires knocked loose from OWS module under the RH seat?
checked all that. All connected and everything. The car has been a in a crash, sent out the module to be reset. Came back with this problem. So i have another module, im going to try it and hope it works.
