overwhelmed- it is radiator now...
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Detaching air pump from its bracket gave plenty of room for the radiator to slide down, easy. Thanks J.
detached air pump
detached air pump
I found the bolts, nuts, and clamps in the proximity of where hoses leak happens most were the hardest, worn, broke, few I sawed out.
first time it takes more time and sweat
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Great job! Sounds like it sure took a bit of effort.
I love that my car has never seen salt.
'98 S70 T5
2016 Chevy Cruze Premier
xHeart
Post by xHeart »
I would pressure wash it clean, and make a speaker of it in youthful days, hang it in the college dorm. Yonder Mountain String Band would sound just right.
Preparing to put it all back together. Replacing most bolts, all three of the special type for the air pump. All Volvo OE parts, one starts to appreciate folks in Volvo parts for their support.
The T40 on thermostat is still not co-operating. For a strong grip, I may stop at the local iron-smith to bend the foot long T40 Craftsman screwdriver to a 90º, make it like allen shaped tool for better grip and turn.
xHeart
Post by xHeart »
The replacement arrived today. What to make of the cuts?
strange saw cuts
strange saw cuts
xHeart
Post by xHeart »
Here are two more at the bottom. Do I ask for a replacement?
two on bottom
two on bottom
JordanW
Year and Model: 96 850R
Post by JordanW »
The cuts are supposedly normal to allow for expansion, though they should not ever go through the actual tubes. http://volvospeed.com/vs_forum/index.ph ... or-defect/
The mashed fins are not normal, was it packed bad?
96 850R = ARD Green m4.4, rip, Kilen's, C70vert subframe, S60R exhaust manifold, NA TB with 960 plate, SNAAB J pipe, MSD coil.
xHeart
Post by xHeart »
The corrogated box was not damaged, fresh and clean.
I called Volvo parts, they sent a replacement, it also has cuts. The meshed fins are much better on replacement.
These cut are not machined since the quality and depth of cuts are abrasive and sharp. Unskilled. It cuts into the first row of meshed fins, leaving it smooshed and uneven. Just poor, a substandard equipment for an extremly critical function, maybe.
I would proceed with installing with MVS support.
xHeart
Post by xHeart »
Now all new and shinny. AWAB stainless steel clamps are something.
replaced seals, clamps, and more...
After few low fluid reminders, it is now holding level. No leaks.
holds fluid level...
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
OMG! A 6 day rad job. Old cars suck some times.
xHeart
Post by xHeart »
I am a rookie Robert with a full-time job, lovely family with a dog in awesome summer days.
I credit you and infamous ABS doctor Matty Moo for this addiction starting November 2011.
