2002 S80 T6 Code P0014 Camshaft Position Sensor
red057
Year and Model: 2002 S80T6
Post by red057 »
Hello, I have a 2002 S80 T6 with 195,000 miles on it. My check engine light is on and one code reads "P0014 Camshaft Position Sensor". The engine seems to be running fine, no visible smoke that I can see from exhaust. If the camshaft position sensor is not replaced can it affect the catalytic converter and damage it? Also how hard is it to replace the camshaft position sensor. any help would be appreciated.
Thanks :D
boosted5cyl
Post by boosted5cyl »
That code has many causes that are NOT cam sensor related. VVT or VVT solenoid issues or a timing belt thats jumped a tooth. VVT issues are more common that actual sensor issues. Depending on whats happening, a VVT or a cam sensor issue may cause harder cold starting, minor roughness while warming up and slightly increased fuel consumption.
