'95 850 spark plug cover screws
Paddler
Year and Model: 850 Turbo 1995
Post by Paddler »
Within the last week I've been losing coolant with no evidence of a leak anywhere. Wanted to check the spark plugs to see if I may have a head gasket problem. Four of the cover plate screws came out with no problem. The other two seem to be stripped inside the screw head. What is the best way (or any other way) to get them out so I can get at the plugs?
neworleans
Year and Model: 2007 S60R
Post by neworleans »
I had the same problem when I did mine PVC. I cracked the cover at between the screw and the motor edge then pulled it out. Before you do this, try to cut the screw head with a metal saw and make a straight slot to be able to turn with a big screw driver.
Has thanked: 311 times
Been thanked: 817 times
I agree, cutting a slot across the screw head is good advice. Best tool for that is going to be a Dremel with a cutoff wheel, if you can access one.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Why do people tighten those screws?
Nitrate
Year and Model: 1993
Post by Nitrate »
rspi wrote:Why do people tighten those screws?
Aluminum head and long time sitting there
rmmagow
Year and Model: V70 1998
Post by rmmagow »
Second thing I did after I bought my car was to remove and anti-seize those screws. I don't think they need to be crazy tight anyway.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
KlubMarcus
Year and Model: V70 XC, 1998
Post by KlubMarcus »
rmmagow wrote:Second thing I did after I bought my car was to remove and anti-seize those screws. I don't think they need to be crazy tight anyway.
I didn't bother putting the spark plug "Volvo" cover back on. It just gets in the way during inspection and maintenance. It's mostly for looks. Anybody want to buy a high-mileage OEM spark plug cover with rusty OEM Torx screws? All original from the factory. Ha Ha!
Original factory spark plug cover and Torx screws!
CIMG1739 (800x448).jpg (240.96 KiB) Viewed 1570 times
:o The beater just won't die! So we're clawing our way back to Stage 0.
Been thanked: 504 times
Post by cn90 »
1+,
I still have the cover on but thinking about getting rid of it.
SimLyons
Year and Model: 2001 V70 T5
Post by SimLyons »
Volvo, as well as just about every car/engine manufacturer hire "Industrial Designers" to take a perfectly fine and accessible engine (from a mechanic's perspective) and make it look sleek and hide all those ugly filters, belts and hoses. You can easily see it now (for the past 20 years) engine design has devolved to the point where in some risiculous models you pay BIG $$$ just to change oil. Once case in point: No dipstick on certain Volvo (and other) transmissions. Why would you need an ugly dipstick when the trans is lubed for life. WHOSE life you might ask? I still don't have an answer but I do know more than one genuine Volvo dealer that won't change the fluid even on request. The owner's manual says so. This is a great way to sell transmissions (and any other rotating lubricated part) where it is stated no service is required.
I know. I got off the topic a bit. (I just bought a new set of screws for my cover. After 15 years they were a little too worn and loose with the torx driver)
Sim
rmmagow
Post by rmmagow »
My neighbor came over and asked if I could look at his Audi for him. WOW, nothing under there that even resembles a motor! I told him I'd probably only break something trying to dig into the car a bit. Probably has no tranny dipstick either. Have to admit though, nice and clean looking under there what you could see.
