DL240 overdrive and kickdown cable on automatic
ed7
Year and Model: V70XC 2005, 2001
Has thanked: 2 times
Post by ed7 »
Unless she's towing a trailer, she doesn't need the OD disengaged. The OD switching is noticeable regardless of which gear the trans is in. The default is disengaged OD.
To eliminate the kick-down, count the shifts the trans goes through as you get up to speed. The kick-down could be out of adjustment or hanging up in the cable sheath. It should have about 5mm slack.
Buy the OD bypass plate if that is the problem
Ed
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
I have had the bypass plate installed on my 1988 760 Turbo Wagon for about 5 years now. it hasn't caused me a second thought.
1988 Volvo 760 Turbo Wagon
lummert
Post by lummert »
Did you try checking for current to the solenoid? I have read about someone finding a broken wire running to the solenoid.
ed7
Post by ed7 »
A broken wire is common under the car. The solenoid doesn't make a lot on noise, it's barely noticable.
If you're getting voltage on the solenoid wire under the car, the solenoid/valve is shot.
Ed
lummert
Post by lummert »
Modifying what you have also works. I was going to suggest that, I just wanted to wait until you checked every last part.
