Hey Guys,
Does anyone here know the type of fuse ( Im guessing that its a fuse ) that goes into the seat.
mine are missing so i dont even know what they look like just wires dangling under neath.
Thanks,
Arnettii
Heated Seats
- Year and Model: Many Volvos
- Been thanked: 76 times
There are no fuses in the seats themselves. The dangling wires are likely the seat thermostat wires. They are a bit of a bear to put back on but it helps if you have someone sit in the seat while you are trying to plug them back in. Be warned, the seat sitter will get goosed pretty good as you try to plug the wires back in so choose your assistant wisely.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Also, know that the thermostats keep the seat heaters from turning on if the temperature of the seat is warmer than 58 degrees (or something like that). So you will likely not get to test them until it cools down a little.
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
There was a recall on the thermostats a few years ago. They caused the element to burn itself out. If you didn't get them replaced at a dealer, the recall may still be in affect and you can get them for free
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
- 2989 Views
Last post by frisky99
- 3558 Views
Last post by jimmy57
- 522 Views
Last post by precopster
- 3285 Views
Last post by Blockpartie
- 17 Replies
- 3592 Views
Last post by wjhandy850
