Volvo 850 heater core replacement 2
This topic is in the MVS Volvo Repair Database » Volvo 850 Heater Core Replacement Tutorial
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
A piece of hose and a dab of silicone on the firewall side should eliminate or drastically reduce the noise. Same link as before (2nd photo) but add some silicone.
http://volvoforums.com/forum/volvo-850- ... nes-46740/
PEWPEW
Year and Model: 855 GLT 1994
Post by PEWPEW »
BKM98 S70 T5 wrote:-
Thanks BKM, I will attempt that over the weekend if it doesn't rain too much :D
1994 850 GLT Estate
1996 850R Estate
1999 V70 T5 Estate
2000 Lexus IS200 1JZ-GTE
1989 Range Rover Vogue
1994 Honda CBR250RR
2 cats.
beoutside
Year and Model: 1999 xc v70 awd
Post by beoutside »
checked out mine and the leak was a evaporator drain hose clog , 5 min fix, make sure to check if your losing coolant!!, plus removing the carpet/ side panels/ kick panels on both sides to see were water is coming from really helps. Mine only leaked when fan was running since the fan cowling was backed up with water !!
1999 V70 x/c AWD
Go Forth and Seek the depths
that create spark in your life......
Or something along those lines :)
Been thanked: 504 times
Post by cn90 »
Just want to add a video to make this complete.
IPD USA has a nice video showing you how to replace Heater Core.
NOTE: IPD recommends clamping the heater hoses (in the engine compartment) to minimize coolant spill inside the cabin:
volvogirl75
Year and Model: 1998 v70
Post by volvogirl75 »
Single mom..all repairs done y myself :)
Bypassed heater core...
slightly overheated after bypassing ...
replaced thermostat ...
refilling water and coolant couple times all of it seems to boil out top of reservoir when car running. Not when idling.
when driving 3-5 miles starts overheating :(
someone mentioned to me liquid glass as temp bandaid if possible cracked head or head gasket ...
I need every opinion I can get!!!
Flat broke! !
Can't even get work ...
about to lose home n job without car :(
MoVolvos
Post by MoVolvos »
Trapped air in the system when you opened it. I couldn't find anything here right off but the link below should help.
http://www.chicagoengines.com/tech/bull ... eating.htm
Post by cn90 »
The thermostat you put in, does it have a hole?
volvogirl75
What do you mean "hole"???
Btw..thanks for trying to help. Very much!!!
Post by cn90 »
A hole in the thermostat allows air to bleed out by itself.
The Factory Volvo thermostat was made by Wahler and it has a hole in it.
Some aftermarket tstats have no holes. What brand of tstat did you put it?
Here is a picture of the bleed hole:
volvogirl75
BKM...
your article was extremely informative! !!
Ill have to wait till tomorrow morning to test it though.
so what I'm reading is...unclamp highest heater hose...pull from radiator ... fill radiator ...clamp hose back to radiator ...top off reservoir again...how long should it take to see a difference? ?
How does that bleed air?
Just
Curious.
How do u bleed air already in cooling system? ?
DEFINITELY TRYING ASAP IN AM!!
