A piece of hose and a dab of silicone on the firewall side should eliminate or drastically reduce the noise. Same link as before (2nd photo) but add some silicone.
http://volvoforums.com/forum/volvo-850- ... nes-46740/
Volvo 850 heater core replacement 2
Volvo 850 Heater Core Replacement Tutorial
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
PEWPEW
- Year and Model: 855 GLT 1994
Thanks BKM, I will attempt that over the weekend if it doesn't rain too muchBKM98 S70 T5 wrote:-
1994 850 GLT Estate
1996 850R Estate
1999 V70 T5 Estate
2000 Lexus IS200 1JZ-GTE
1989 Range Rover Vogue
1994 Honda CBR250RR
2 cats.
1996 850R Estate
1999 V70 T5 Estate
1994 Honda CBR250RR
2 cats.
beoutside
- Year and Model: 1999 xc v70 awd
checked out mine and the leak was a evaporator drain hose clog , 5 min fix, make sure to check if your losing coolant!!, plus removing the carpet/ side panels/ kick panels on both sides to see were water is coming from really helps. Mine only leaked when fan was running since the fan cowling was backed up with water !!
1999 V70 x/c AWD
Go Forth and Seek the depths
that create spark in your life......
Or something along those lines
- Been thanked: 504 times
Just want to add a video to make this complete.
IPD USA has a nice video showing you how to replace Heater Core.
NOTE: IPD recommends clamping the heater hoses (in the engine compartment) to minimize coolant spill inside the cabin:
volvogirl75
- Year and Model: 1998 v70
Single mom..all repairs done y myself
Bypassed heater core...
slightly overheated after bypassing ...
replaced thermostat ...
refilling water and coolant couple times all of it seems to boil out top of reservoir when car running. Not when idling.
when driving 3-5 miles starts overheating
someone mentioned to me liquid glass as temp bandaid if possible cracked head or head gasket ...
I need every opinion I can get!!!
Flat broke! !
Can't even get work ...
about to lose home n job without car
Flat broke! !
- MoVolvos
Trapped air in the system when you opened it. I couldn't find anything here right off but the link below should help.
http://www.chicagoengines.com/tech/bull ... eating.htm
volvogirl75
What do you mean "hole"???
Btw..thanks for trying to help. Very much!!!
A hole in the thermostat allows air to bleed out by itself.
The Factory Volvo thermostat was made by Wahler and it has a hole in it.
Some aftermarket tstats have no holes. What brand of tstat did you put it?
Here is a picture of the bleed hole:
volvogirl75
BKM...
your article was extremely informative! !!
Ill have to wait till tomorrow morning to test it though.
so what I'm reading is...unclamp highest heater hose...pull from radiator ... fill radiator ...clamp hose back to radiator ...top off reservoir again...how long should it take to see a difference? ?
How does that bleed air?
Just
Curious.
How do u bleed air already in cooling system? ?
DEFINITELY TRYING ASAP IN AM!!
Just
Curious.
- 11 Replies
- 9874 Views
- 5093 Views
- 32 Replies
- 17821 Views
Last post by sleddriver
- 1251 Views
Last post by polskamafia mjl
- 48 Replies
- 7779 Views
Last post by RigsPGT
