'97 850NA-7 bolts are off, but water pump won't...
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Using tb procedure for replacing water pump. Is there gentler way to take it off. It feels the last service used jbweld not RTV.
Tia.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Is there any way you can wedge a crowbar behind the belt drive gear and pop that sucker off? Or grab it with some huge monkey wrench there?
I wouldn't pry between it and the engine block for fear of damaging the mating surface.
'98 S70 T5
2016 Chevy Cruze Premier
Been thanked: 504 times
Post by cn90 »
? Maybe put a floor jack + a short piece of 2x4 wood below the WP and gently jack it up.
xHeart
Post by xHeart »
Is the plastic tb cover behind removable, preventing it from breaking?
Post by cn90 »
xHeart wrote:Is the plastic tb cover behind removable, preventing it from breaking?
Volvo 5-cylinder: How to Replace the Head Gasket
xHeart
Post by xHeart »
There is a reference to dowels, yellow dots? Is it something need removing along with 7 bolts?
Post by cn90 »
If you are sure that all 7 bolts are out, then from ABOVE, use a 2x4 wood, then gently tap it with a hammer, the WP will fall off to the ground.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
It's got to come off so just get rough with it. The block is very hard, hard to damage but just don't scar it with a pry tool.
jblackburn
2x4 sounds like a good idea, and you can whack it with something big from the top.
There are two metal tabs on the hood hinges. Let the hood down a bit, then pull these tabs out and put the hood back up - it will go straight up at a 90 degree angle, which may give you more room to swing something at the 2x4.
'98 S70 T5
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Get a mirror and make sure all the bolts are out.
