Using tb procedure for replacing water pump. Is there gentler way to take it off. It feels the last service used jbweld not RTV.
Tia.
'97 850NA-7 bolts are off, but water pump won't...
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Is there any way you can wedge a crowbar behind the belt drive gear and pop that sucker off? Or grab it with some huge monkey wrench there?
I wouldn't pry between it and the engine block for fear of damaging the mating surface.
'98 S70 T5
2016 Chevy Cruze Premier
xHeart
Is the plastic tb cover behind removable, preventing it from breaking?
- Been thanked: 504 times
Volvo 5-cylinder: How to Replace the Head GasketxHeart wrote:Is the plastic tb cover behind removable, preventing it from breaking?
xHeart
There is a reference to dowels, yellow dots? Is it something need removing along with 7 bolts?cn90 wrote:Volvo 5-cylinder: How to Replace the Head GasketxHeart wrote:Is the plastic tb cover behind removable, preventing it from breaking?
If you are sure that all 7 bolts are out, then from ABOVE, use a 2x4 wood, then gently tap it with a hammer, the WP will fall off to the ground.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
It's got to come off so just get rough with it. The block is very hard, hard to damage but just don't scar it with a pry tool.
jblackburn
2x4 sounds like a good idea, and you can whack it with something big from the top.
There are two metal tabs on the hood hinges. Let the hood down a bit, then pull these tabs out and put the hood back up - it will go straight up at a 90 degree angle, which may give you more room to swing something at the 2x4.
'98 S70 T5
- 520 Views
Last post by DXC70
- 1983 Views
Last post by MadeInJapan
- 30 Replies
- 1531 Views
- 1303 Views
Last post by Nevada1906
- 5014 Views
Last post by kallekula
