left-handed drill bit on stripped t-stat T40...
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
After much deliberation with MVS DIYers, see .../viewtopic.php?f=1&t=34806&start=28
I am choosing 1/4" left-handed drill bit to extract, drill out the stripped T40 from t-stat upper housing. The fuel line on disconnected at the rail, sealed and protected.
Any word of caution for before of after this task?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
No, just drill the head of the bolt off. Once the head is free, take the housing off and remove the rest of the bolt with vice grips or something. Do not try to drill the entire bolt out.
Are you changing the t-stat? Was the car running cold? That's another thing people change with the temp sensor for no reason. :?
xHeart
Post by xHeart »
T-stat works fine.
Since I have water pump replacement at hand, conditions are just right to replace the stripped T40.
If thermostat fails, it will fewer steps to replace. I have a blue box.
I will slide and screw in the stopper, and won't drill pass the head depth.
Been thanked: 504 times
Post by cn90 »
I just replaced my tstat last weekend.
Watch out for falling debris (crumbling gasket), put a rag in there to catch debrios.
I posted the DIY here:
https://www.matthewsvolvosite.com/forums ... 5&p=252696
xHeart
Post by xHeart »
cn90 wrote:I just replaced my tstat last weekend.
Very timely cn90.
xHeart
Post by xHeart »
Using oil does make drilling not only smooth, it keeps the shavings together. I still have shank to pull out.
1/4" left-handed drill bit with stopper, and removed T40 screw head
head is drilled out...
shank still has to come out...
mrwillie
Year and Model: 1994 855 base
Post by mrwillie »
xHeart wrote:Using oil does make drilling not only smooth, it keeps the shavings together. I still have shank to pull out.
Are you using grip pliers to get the shank out?
xHeart
Post by xHeart »
I am thinking of using the two nut technique. It is discussed in the link I referenced above.
mrwillie
Post by mrwillie »
I'll look again, but I really don't understand what he was doing w/ the nuts stacked on top of each other. Not sure how that would back the screw shank out.
xHeart
Post by xHeart »
Plausible.
Would the nut thread from the top? It may go in counterclockwise.
I have posted the questing to Jim.
