I ordered a replacement control arm (driver's front) but it did not come with any mounting hardware, just 3 bolts with nuts. In every aspect, it is the same as the control arm that I'm replacing...it just doesn't have the mounting hardware.
The mounting hardware that I'm referring to are the ones that the bolts that go through the sub frame and into the square nuts that are on each side of the rubber fittings.
The mounting hardware is on the old control arm...I need to know if the old mounting hardware comes off and how.
I can't find any reference on the web or in the forums. It seems that when I've viewed video that some replacement control arms come with the mounting hardware.
I don't want to be prying or twisting without knowing what I should be doing.
Thanks in advance for your help. Hope I've been clear.
Need direction on Replacing Lower Control Arm 98 V70XC
JDS60R
- Been thanked: 3 times
This is as close as I could get. its not listed under the xc70 but is listed under V70 AWD
98 V70 AWD B5254T front control arms.pdf- (676.57 KiB) Downloaded 275 times
Retired
petek153
- Year and Model: 1992 940T
Not sure but looking on line at parts but looks like the new parts you have are for the V70 and the ones you should have are for V70 AWD if your car is a AWD. If its a AWD control arms are different and come with the pieces your talking about already installed in control arm. Just my thoughts on it.
92 940 turbo
93 850 GLT sold
94 850 GLT
96 850 GLT my parts car (:
96 850 T_BONED ):
97 850 BASE
93 850 GLT sold
94 850 GLT
96 850 T_BONED ):
97 850 BASE
Thanks everyone for the assistance.
Petek153 - you put me on the right track.
There is a 2 bolt model and a 4 bolt model replacement control arm. My 1998 V70XC has the 4 bolt model.
Back to the parts department.
Thanks again.
Thanks again.
