PCV - saying goes, if it has 100k, just do it...
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
After no delays in responses from MVS Mavericks the cooling and heating project, water pump, thermostat, radiator, and tb service, was a huge success for me.
Introduced to PCV along the way, this is the kit I found for 97 850 NA products/5436/115322-pcv-breather-system-kit-1993-1997-850-non-turbo.
Would this be a good time for tune up?
TIA.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Sure...
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Is it smoking?
'98 S70 T5
2016 Chevy Cruze Premier
xHeart
Post by xHeart »
jblackburn wrote:Is it smoking?
Visible without my glasses on. It pumps out smoke rapidly with the pulsating of engine.
jblackburn
Then I think you know what I'm going to say.
Do it! ;)
'98 S70 T5
xHeart
Post by xHeart »
I now have tools for this job. Added a set of magnetic sockets for 1/4" drive, and flex ratchet wrench. Looked around the work area for comfort.
If recommended, I would try the crimp clamp with Oetiker.
I believe, these are fixed size clamps, there are 4 clamps of one size, and 2 of other, total of 6.
What are these two sizes?
OR should I stick to worm type?
rspi
Post by rspi »
I've used both. Kinda like the Oetiker clamps but they are only one time use. IPd will ship you the worm style while FCP will ship you the others. I guess you'll use whatever comes in the kit.
xHeart
Post by xHeart »
The two worm sizes are 22-32 (x2), and 15-24 (x4).
The oetiker/crimp kind clamp is sold with ring dimension in mm. I will look at FCP kit online.
xHeart
Post by xHeart »
There are several steps before getting to intake manifold, hence PCV parts replacement. There is IAC, and throttle control with their clamps, hoses, connectors, flame trap, and more. It is hard to bypass if these two need care, cleaning and replacing.
How to prevent failure of these two?
I am starting out with IAC and its hoses, which are not clamped on the other end.
The clamp is new to me, the design suggests, these are reusable, is it?
Is hose quality a visual inspection?
IAC with inlet and outlet hoses
xHeart
Post by xHeart »
The two 12mm bolts underside the intake man, one fastening the dipstick assembly, are not a straight shot from below, even if I remove the air guide/pan. It would have to be worked out from the above.
Learning from fuel filter replacement, the bracket was twisted while removing the old fuel filter. Is there a need for PB Balster, would turning bolt twist and damage the bracket holding the dipstick assembly?
