I've been working on getting my V70 running again. A bad radiator caused brown milkshake, overheating, then head warpage.
So I pulled the head and the radiator off, had the head shaved, replaced the head gasket, had a lot of trouble with the oil return pipe and o-ring, and now, getting the radiator back together I CANNOT FIGURE OUT WHERE THIS PLASTIC PIECE CAME FROM. It came off when I took the radiator off, and so I assume it comes from there, but the shape is so odd that no obvious place for it stands out.
Also, I torqued the radiator bolts down today and found that there was still front-to-back play (the radiator bolts acted as a pivot point). On my 940 there is a cross-member on top of the radiator, which prevents this type of movement. Maybe it has something to do with that?
I've been through VADIS diagrams for a few hours and through the Haynes manual, with no luck in identifying this piece.
I'll be impressed and in debt with gratitude if you are able to help me out.
See pictures attached.
1998 V70 2.5L Turbo part ID? (Solved: battery clamp)
Felix_saenz
- Year and Model: 1998 Volvo V70 AWD
Felix_saenz
Felix_saenz
Felix_saenz
Felix_saenz
Well that's pretty simple. Thank you! It does, I did not want to proceed without knowing where it belongs.
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
That part had me pretty thoroughly confused too! Had a good laugh at myself once I realized what it did.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
- 11 Replies
- 1825 Views
- 1816 Views
Last post by dudeitssm
- 2041 Views
- 4514 Views
Last post by JacksonTNTurbo
- 569 Views
Last post by P80GLT
