Official Engine Stalling Thread
This topic is in the MVS Volvo Repair Database » Secondary Air Injection System Diagram
Locked
rosson
Year and Model:
Post by rosson »
I had the same issue
Electrical connection.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Glad you found it...others should check there and do preventative maintenance! I will do it too as soon as I get off of here...haven't really looked there to be honest with you.
sibir
Year and Model:
Post by sibir »
A long while ago (10 months?) my 850 started stalling, I cleaned the EMF and it seemed to help but not to eliminate the problem. I looked at the fuel pump relay (green) and it looked like new inside. So I did not change it.
Then, as it got warmer the stalling at deceleration pretty much went away (now once a month at most), but now I have a very repeatable problem. After stopping the warm engine for a few minutes for an errant it will not start again for a couple more minutes, maybe for 2-3 minutes after the first attempt. Since it only happens in the parking lot it is more a nuisance than a problem but I wonder if the two are related. Anybody else seen this?
MadeInJapan
There is a great diagnostic run-through in the 850 Service Manual for non-start and stalling conditions. I think everyone who's posted on this very long thread and their issues are still unresolved should get it. You can now download it from here for free! : https://www.matthewsvolvosite.com/chat/p ... php?t=8018
EMO 850
Year and Model:
Post by EMO 850 »
Count me in! my '94 850 2.0 20V has the same problem stalling while driving, very randomly could drive 100 miles one day no problems then do 3 miles the next and it stalls 3 times! I have to wait around 2-3 minutes then it starts first time very anoying and dangerous!
And again it starts first time from cold, could drive 2 miles down the road and stop for 2 minutes then it wont start unless I give it some throttle.
had a mechanic use diagnostic computer on it he spent 2hours checking it and driving it and it didn't miss a beat, with no electrical faults etc.
looking at previuos posts im going to clean the throttle body and hope for the best! :D
MadeInJapan
Your problem sounds like it could be a bad ignition switch. With car running, try jiggling your keys.
david hyde
Year and Model:
Post by david hyde »
I've been suffering this problem for more or less the past year (with a 1995 850 GLT Estate which I've had from new). Completely unpredictable - but the engine just dies and then takes several minutes to restart, but can take up to 30 minutes. Happens without warning and without any recognisable pattern.
It's spent nearly 3 weeks in the garage trying to locate the problem - but of course to no avail. They replaced the cam sensor, but still no improvement.
So we decided to tackle this logically - it must be either the electronic engine management system at fault, or some failure in the fuel delivery. So first thing we did was to change the fuel filter - and in doing so we found what we think is the cause:-
Below the filler cap is a very small air vent (you have to look carefully to find it). A piece of the trim around the filler hatch had come away (the piece that's meant to catch the drips of petrol when refuelling) and was lodged and covering the air vent. This, of course, would cause a vacuum to build up in the fuel tank - and, if so, would result in no fuel getting through to the engine.
It would explain the unpredictability - and also the variation in restart times. Plus it would explain why no garage can identify the fault by running diagnostic tests.
The car's been running fine since we've made this discovery - although that's only a week.
So my advice to anyone suffering this problem is to first check the vent below the filler cap - it could save you a great deal of money in garage bills.
lambertmt
Year and Model:
Post by lambertmt »
I'm getting a consistent sputtering or lugging when I push the throttle and the engine is between 500 & 1500 RPM. It feels like the engine is misfiring: jerky and rough.
I have a manual transmission, so I know it's not that. This happens after I put it in gear. For instance, if I'm in a high gear at low RPM and push the gas, it jerks.
This problem happens less frequently when I use Amoco Ultimate (93 octane) than it does when I use cheap gas.
Car has 156K miles.
Any ideas?
'97 854
5 spd man
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
lambertmt wrote:I'm getting a consistent sputtering or lugging when I push the throttle and the engine is between 500 & 1500 RPM. It feels like the engine is misfiring: jerky and rough.
Car has 156K miles.
Any ideas?
what have you tried? fuel additive is dead simple and cheap. checking vacuum hoses for cracks is also quick and painless. they're the white small tubes in the engine bay.
Also -> Amazon link
lambertmt
Year and Model:
Post by lambertmt »
I haven't tried anything yet. It feels like some of the cylinders misfire.
I will certainly try fuel additive, but what do you think could be the root cause? I have the sense that it's part of the fuel delivery subsystem, but I don't know the particular components well enough to venture a guess. It might be too much fuel that floods the chamber ...
thanks,
Michael.
'97 854
5 spd man
Locked
