Turn signals and shift interlock fail together
jmailloux
Year and Model: V70R 1998 Silver
Post by jmailloux »
Hey,
My 1998 V70R (163k miles) has this odd thing where the turn signals stop working entirely and the transmission shift intelock also fails (you have to press the override button to the right of the shifter to get it into gear). These two happen pretty much together, and it has happened 3 - 4 times, but infrequently, spread over weeks. Not much in common among the incidents.
When the turn signals fail, they are completely dead, nothing blinking or steady, inside car or outside.
I replaced the emergency flasher unit about a year ago.
Any ideas? Should these two things be related at all? I checked various fuses, all seem fine. And both these things work most of the time, but this dual random failure thing is annoying..
Thanks,
Jim.
_____________________________
1998 V70R Silver 180k
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Sounds very much like the failing contact block of your ignition switch.
Next time it happens, give the key a little jiggle.
jmailloux
Post by jmailloux »
Thanks, I will try that. Sounds like the only thing those two would have in common.
Is the permanent fix to replace the ignition switch? Any info on that?
Thanks!
BEJinFbk
Post by BEJinFbk »
Copious amounts - Search will always find it for you:
https://www.matthewsvolvosite.com/search ... j941534j15
jmailloux
Post by jmailloux »
Thanks again! You are correct; lots of info on it. I will be ordering the switch tonight....headlights did not automatically come on until I jiggled the key around a bit after starting, which is a new symptom....
