Okay so I am replacing both front drive shaft because of torn CV boots. Got the old ones out and new ones in but can not figure out how to get the ball joint to go back into the control arm. I can push the control arm down (until in bottoms out) but still need another 2 inches to get the ball joint back into the control arm hole. When I jack up the wheel it just pushes out and is not aligned with the hole.
Do I need to compress the springs? Something else? Please let me know any idea.
Here is a youtube link to what I did, unfortunately it does not go into an reassembly details.
Thanks for any info.
How to get ball joint back into control arm?
- Has thanked: 2857 times
- Been thanked: 1332 times
On 850s I've run into a similar problem, where the ball joint would simply not seat in its mate. So we took the control arm (back) off of the frame of the car. This frees up the control arm so that you can mate the ball joint first, then do the two frame bolts.
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
Make sure the ball joint is clean, put some anti-seize in it then manipulate it where it's at the right angle to go straight in. Depending on how stubborn it is, I've found that using a rubber mallet coaxes it into place.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Probably a bit late now, but the bolts you loosened are used to hold the camber in position. Might be a good idea to get your alignment checked, or at the very least throw a digital angle finder on there.
- 10 Replies
- 4716 Views
Last post by oragex
- 15 Replies
- 3731 Views
- 4157 Views
Last post by Tonyx
- 12 Replies
- 5608 Views
Last post by darrylrobert
- 9 Replies
- 7190 Views
Last post by BrianV70
