223,000....
PCV serviced: Replaced tank, all pipes, elbows.
PTC is clear.
ABS Controller pins reflowed.
Sparkplugs replaced, gapped to .28".
PNP switch stripped and serviced contacts
IAC valve cleaned
Turbo piping clear of oil
Shaft play appears to be OK.
Boosted's '98 T5 V70
Forum rules
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
boosted5cyl
Two nice new shiny tires on front.
boosted5cyl
9/30/12 225000 (approx)
Replaced L and R control arms incl balljoints ($98 ea @ NAPA)
Front aligment...2mm tow in total @ 16"
Drained and filled tranny with 3.5 qts
Fluid was dark in color/dirty but did not smell burnt and had no signs of metallic particles.
Oil and filter change, Mobil 0w30
Mann filter with anti drainback valve
